Simple address add (.) special charcters
hi
wanted to know if i can change the validation of the simple address to allow extensions ?
for example name in url can contain aaa.html but the simple address i get an error
  • "iii.htm" is not a valid value for "Simple address". Only the following characters are allowed when constructing the simple address: a-z, 0-9, -, _, ~, /
any suggestions ?
#82475
Mar 13, 2014 10:46
ok, didn't get an answer so i tried using ISAPI_Rewrite 3  from helicon.
the problem now that the rewrite rules does a 301 to the new address  ( i think it and epi write problem)
#82756
Mar 19, 2014 13:00
You can create a custom segment that looks at poperty on page to get around the simple url validation.
Try doing this in initialization module it should prevent the 301
var type = typeof(UrlRewriteProvider);
var field = type.GetProperty("FriendlyUrlExtension");
field.SetValue(null, ".html", null);
#82796
Mar 20, 2014 7:04
