You should add a default tag to your content area rendering.
@Html.PropertyFor(x => x.CurrentPage.MainContentArea, new {tag = Global.ContentAreaTags.FullWidth })
This way, it will use the "FullWidth" tag when "automatic" is chosen.
Thanks a bunch! I knew there had to be one piece missing in the puzzle.
Hello
I have a problem that is driving me nuts, and I'm hoping someone can help me;
I have a block that is set to be displayed only in full width using the approach from Alloy 7.5
When I add the block to a content area (and Display As gets set to Automatic) it is not displayed, instead I get the error "... can not be displayed".
When I set Display as to full width it is displayed correctly.
When I run the Alloy package the Jumbotron block is displayed with the full template even if Display as is set to Automatic.
I have tried all sorts of things but I simple can not get this working.
What have I missed? What is required in order for this to work.
Fredrik
