Adding NAS disk to EPiServer
Pär Wissmark
Pär Wissmark
workspace_premiumCMP Administrator CertificationCommerce Connect 14 Developer CertificationDXP Administrator CertificationSaaS CMS Developer CertificationCommerce Connect 13 Developer CertificationExperimentation Strategist Certificationworkspace_premiumPaaS CMS Administrator CertificationSaaS CMS Developer (Expert) CertificationSaaS CMS Administrator Certificationworkspace_premiumPaaS CMS Developer CertificationOpal Administrator CertificationOpal Tools Certificationworkspace_premium
Hi all
I want to add a NAS disk/folder to EPiSver 7.5, i cant seem to find any info regarding this since the file handling has changed.
/P
#82632
Mar 17, 2014 13:17
I think there is no equivalent of the VirtualPathNativeProvider for the new media system.
You could create your own BLOB provider and see how far you can take it but I think you will run into to problems exposing the folder structure since it is now shared between blocks and files.
It is also possible to use the Migration Tool and copy files from a VirtualPathNativeProvider into the new media system but that will be a one time thing and not the "mirroring" type of functionality it sounds like you're after.
#82715
Mar 18, 2014 15:19
Pär Wissmark
Thanks for the reply
I have added an support issue as well, we have a few intranet solutions that needs this function.
Do you have any thought on how to work around this.
/P
#82894
Mar 21, 2014 9:12
Since the insertions of files from the VirtualPathNativeProvider weren't "permanent" ones, just /vpp-path/folder1/file1.pdf etc, I think the fastest way forward would be to create your own TinyMCE-plugin where you open a tool window with a typical file browser view for your file share starting point. Outside of EPi I'm guessing there should be a bunch of examples of this for TinyMCE and ASP.NET.
Note that I haven't at all looked into if this could work but another possiblity would be some combination of Page provider to expose the file share's folders below a fixed starting point and BLOB provider.
#82900
Mar 21, 2014 9:56
Pär Wissmark
Ok, thanks a lot
Ill dig into this and post when I find a good way to solve this
#82910
Mar 21, 2014 10:46
Pär, How did you solve the mirroring issue?
#115807
Jan 19, 2015 13:45
Pär Wissmark
We solved it by doing a pagetype and a blocktype that lists a shared folder. We used FooTable (http://fooplugins.com/plugins/footable-jquery/) to present the files. This was the quick fix. We have a new solution that we havent finished yet. The new way will be to build a mediaprovider, http://world.episerver.com/blogs/Johan-Bjornfot/Dates1/2014/8/LocalMediaProvider/
Hope that helps
/P
#115810
Jan 19, 2015 13:57
