In EPiServerFramework.config we had <scanAssembly forceBinFolderScan="false"> and by changing this to <scanAssembly forceBinFolderScan="true"> we solved the issue above.
Happy days! :-)
I'm trying to migrate vpp files for a site we upgraded from version 6 => 7 => 7.5. The site is up and running and works. But when i run vpp migrating tool and select the site and click Connect i get the following error. Does anyone know how to get around this?
Cannot resolve dependencies for the following module(s)
EPiServer.Initialization.BlobRouterInitialization
EPiServer.Initialization.CMSDynamicDataStoreInitialization
EPiServer.Initialization.CmsDataInitialization
EPiServer.Initialization.DynamicContentInitialization
EPiServer.Initialization.ParentRestoreInitialization
EPiServer.Initialization.SearchInitialization
EPiServer.Initialization.VirtualPathProvidersInitialization
EPiServer.Initialization.XFormsInitialization
EPiServer.Scheduler.SchedulerService
EPiServer.Initialization.SaveConfigToDatabaseInitialization
EPiServer.Initialization.WebIdentityInitialization
EPiServer.Initialization.CmsCoreInitialization
EPiServer.Initialization.PlugInInitialization
EPiServer.Initialization.ModelSyncInitialization
EPiServer.Initialization.UrlRewriteProviderInitialization
EPiServer.Web.InitializationModule
at EPiServer.Framework.Initialization.InitializationEngine.CreateDependencySortedModules(IEnumerable`1 modules)
at EPiServer.Framework.Initialization.InitializationEngine.Initialize(HostType hostType)
at EPiServer.Framework.Initialization.InitializationModule.Initialize(HostType hostType)
at EPiServer.Framework.Initialization.InitializationModule.FrameworkInitialization(HostType hostType)
at VppMigrationTool.Util.SiteProxy.InitalizeEPiServer(String webConfigPath) in d:\Builds\132\EPiServerCMS Modules\VppMigrationTool\Sources\C\TFS\VppMigrationTool\Util\SiteProxy.cs:line 52
at VppMigrationTool.Util.SiteProxy.Initialize(String destinationPath, String virtualDirectory) in d:\Builds\132\EPiServerCMS Modules\VppMigrationTool\Sources\C\TFS\VppMigrationTool\Util\SiteProxy.cs:line 129
at VppMigrationTool.Converter.get_RuntimeProxyWrapper() in d:\Builds\132\EPiServerCMS Modules\VppMigrationTool\Sources\C\TFS\VppMigrationTool\Converter.cs:line 52
at VppMigrationTool.Converter.FillSiteData() in d:\Builds\132\EPiServerCMS Modules\VppMigrationTool\Sources\C\TFS\VppMigrationTool\Converter.cs:line 101
