TinyMCE Changes Aren't Applied Unless Formatting Is Cleared First
Hi Guys,
We're having an issue with rich text editing via TinyMCE. If I go to apply a style to a block of text in the editor, it gets applied as expected. But when I go to apply a different style that should override the original style, things go a little haywire. As you can see, we've defined a set of styles as "h1", "h2", "h3". When I apply "h3" to a section, it wraps the text in a . When I apply "h2" it appends the header2 class like:
afforded the same full scope collective bargaining rights as workers in the private sector.
Hmm. Maybe I can fix it by selecting that section and applying "Standard Text":
It seems like the only way to resolve the issue is to click on the HTML button and clear out all the tags so that TinyMCE can make a fresh start. I guess the question is, *adding* style declarations here is pretty easy, but how do you make sure they get *removed* when the user selects a different style?
Thanks in advance for any advice...
--Ian
#114703
Dec 18, 2014 17:38
