It's been moved to the Settings-tab. At the very bottom there is a label called Shortcut with a Manage link, this link will give you a popup with the shortcut type options you describe.
//Mathias
ok, thats clear. Strange that the functionality stoped working on front end (it is not redirecting). I have to look in to it how it is implemented from start.
Just upgraded from CMS 6 R2 to 7.15.
Where is the shortcut tab in edit mode?
The functionality is also gone on the front end. am I suppose to do another way?
Im missing "Link type" "Internal Shortcut/Fetch Data from" and "Target frame"
