Setting the channel to default to ~/globalassets/ seems to be the solution here.
With the following channel config, pushing files into the global library works.
/Jonas
Is it possible to use the ImportFile() operation in the ContentChannelService to import files into a Global Assets folder?
So far, I've only been able to import files directly into the blob or as a page file. If I try to pass in the content Guid of the SysGlobalAssets (or any global assets folder), the web service throws a null ref exception.
Based off method naming in the EPiServer.ContentChannels.ContentMediaHandler, specifically the ImportContentAssetMedia() method, I'm assuming that the web service doesn't support importing files into global assets.
Am I missing something?
