If you want it to be multiline, just add:
[UIHint(EPiServer.Web.UIHint.Textarea)]
But you might just want a little more width?
Does this apply to all text boxers or just some specific ones?
If all: There is some examples in Alloy Templates on how to implement your custom css-files.
With that you should be able to change the styling of the text boxes. Use firebug or similar to see if you can find a good selector
All text boxes, yes
ok thanks, I'll have a look at the alloy package
Check out this article, under the heading "Adding a backgroud device image" you can see how to add css files.
http://world.episerver.com/blogs/Stefan-Torstensson/Dates/2012/12/Adding-a-new-device-to-the-view-resolution-drop-down/
However what the content for the .css file you can find by using the developer tools in your browser
Tanks Alf!
Since I already had a Styles.css in my /ClientResources/Styles, i just added the corresponding classes from dojo there!
If you don't have it there, just must add it, and insert this into the module.config
<clientResources>
<add name="epi-cms.widgets.base" path="Styles/Styles.css" resourceType="Style"/>
</clientResources>
For the textbox fix, I just added:
input.dijitInputInner { width: 500px !important; }
div.dijitTextBox { width: 500px !important; }
Just change the width as you prefer
Fredrik
Is there a way to make the short string textbox any larger? It is so short now
Looked into EditorDescriptor but can't find a way to do it...
Any ideas?
