PageCriteriaQueryService.FindPagesWithCriteria failing with wait operation timed out
I just starting having this issue with the PageCriteriaQueryService.FindPagesWithCriteria.
It works well on my development machine, local sql server and website, even when I grab the test database it all works fine.
I can point my local site the test database and then it fails also.
It fails with:
[Win32Exception (0x80004005): The wait operation timed out]
[SqlException (0x80131904): Timeout expired.  The timeout period elapsed prior to completion of the operation or the server is not responding.]
   System.Data.SqlClient.SqlConnection.OnError(SqlException exception, Boolean breakConnection, Action`1 wrapCloseInAction) +392
   System.Data.SqlClient.TdsParser.ThrowExceptionAndWarning(TdsParserStateObject stateObj, Boolean callerHasConnectionLock, Boolean asyncClose) +815
   System.Data.SqlClient.TdsParser.TryRun(RunBehavior runBehavior, SqlCommand cmdHandler, SqlDataReader dataStream, BulkCopySimpleResultSet bulkCopyHandler, TdsParserStateObject stateObj, Boolean& dataReady) +4515
   System.Data.SqlClient.SqlDataReader.TryReadInternal(Boolean setTimeout, Boolean& more) +660
   System.Data.SqlClient.SqlDataReader.Read() +37
   EPiServer.DataAccess.ContentListDB.ReadCustomProperties(DbDataReader reader, Dictionary`2 allFetchedItems, Boolean isReadingVersions) +800
   EPiServer.DataAccess.ContentListDB.ReadPublishedList(DbCommand cmd) +317
   EPiServer.DataAccess.<>c__DisplayClass24.b__23() +729
   EPiServer.Data.Providers.<>c__DisplayClass1`1.b__0() +60
   EPiServer.Data.Providers.SqlTransientErrorsRetryPolicy.Execute(Func`1 method) +1265
   EPiServer.DefaultContentProvider.BatchLoad(IList`1 contentLinks, Func`2 dbLoader) +303
   EPiServer.DefaultContentProvider.LoadContents(IList`1 contentReferences, ILanguageSelector selector) +562
   EPiServer.Core.ContentProvider.GetScatteredContents(IEnumerable`1 contentLinks, ILanguageSelector selector) +486
   EPiServer.Core.ContentProvider.LoadBatched(IList`1 contentReferences, ILanguageSelector selector) +222
   EPiServer.Core.DefaultContentLoader.GetItems(IEnumerable`1 contentLinks, LoaderSettings loaderSettings) +770
   EPiServer.DataAbstraction.SearchPages.FindAllPagesWithCriteria(PageReference pageLink, PropertyCriteriaCollection criterias, String languageBranch, ILanguageSelector selector) +312
   EPiServer.Core.DefaultPageCriteriaQueryService.FindPagesWithCriteriaInternal(PageReference pageLink, PropertyCriteriaCollection criterias, String languageBranch, ILanguageSelector selector, FindPagesWithCriteriaDelegate findPagesDelegate) +499
   EPiServer.Core.DefaultPageCriteriaQueryService.FindPagesWithCriteria(PageReference pageLink, PropertyCriteriaCollection criterias, String languageBranch, ILanguageSelector selector) +152
At the time I am simply trying to find pages of a certain pagetype.
In total the site only contains 2900 pages.
Any ideas why it might be failing on the test environment ?
regards,
Danny
#113101
Nov 13, 2014 9:51
You could try to rebuild the sql indexes for the test database (if you google for sql server rebuild index you will find scripts for how to do it).
#113143
Nov 14, 2014 8:12
