using System;
using EPiServer.Core;
using EPiServer.DataAbstraction;
using EPiServer.Shell.ObjectEditing;
using EPiServer.Shell.ObjectEditing.EditorDescriptors;
namespace Samples
[EditorDescriptorRegistrationAttribute(TargetType = typeof(ContentData))]
public class SiteMetadataExtender : EditorDescriptor
foreach (ExtendedMetadata property in metadata.Properties)
if (property.PropertyName == "iversionable_shortcut")
property.GroupName = SystemTabNames.PageHeader;
property.Order = 9000;
return;
My way to find the name for this property (that is actually a bunch of properties in a virtual block) was to put a breakpoint in the loop and just run through it until I found it.
I've used Joels approach here to move the Category property to other tabs with success.
Is it possible to move the Shortcut property as well?
I haven't been able to find the corresponding property name yet (for category the property name is "icategorizable_category").
