Configure the blob path in a load balanced environment
blobs automatically placed in AppData folder, but how can I use a commen share in a load balanced environment?
Where do I change the path?
Since episerverframework and episerver config files are gone, I guess the configuration is in web.config... but here is only the AppData basePath="", I guess changing this would affect aother things..?
Please help :)
Fredrik
#112766
Nov 05, 2014 11:36
Forgot to mention, this is EPi 7.5 and version 7.14.2
#112767
Nov 05, 2014 11:48
In EPiServerFramework.config, you should see this:
  <appData basePath="<somepath>" />
This can be shared in load-balancing environment.
Regards.
/Q
#112772
Nov 05, 2014 12:05
You can specify the standard blob provider (FileBlobProvider) path liks this:
  <episerver.framework>
    <blob defaultProvider="fileShare">
      <providers>
        <add name="fileShare" path="\\dbserver\blobs" type="EPiServer.Framework.Blobs.FileBlobProvider, EPiServer.Framework" />
      </providers>
    </blob>
#112773
Nov 05, 2014 12:10
Tried that, but
is not valid ...(Unrecognized attribute 'defaultprovider')
And no, the EpiserverFramework file is gone... or should I make one just for this purpose?
#112774
Edited, Nov 05, 2014 12:12
It's the
section which matters. You can change the AppData basePath in web.config.
#112776
Nov 05, 2014 12:14
Freguz,
The episerver.framework file has been moved into the web.config file, in a <episerver.framework> section. There you will also find <appData basePath>.
Example:
  <configuration>
    .... lots more settings
        <providers>
        </providers>
      </blob>
      <appData basePath="App_Data" />
      ... more settings
    </episerver.framework>
  </configuration>
#112777
Edited, Nov 05, 2014 12:32
And remember that config settings are case sensitive, so make sure you have a capital P in defaultProvider
#112778
Nov 05, 2014 12:35
Thanks all! It works fine now, and thanks Per it is case sensitive I had the lowercase p :-/
/Fredrik
#112794
Nov 05, 2014 15:03
One thing you can do in a load balanced enviroment is to have for example DFS to sync your local AppData folder.
#112803
Nov 05, 2014 16:26
