It is just a static boolean property that you typically you would like to set during initialization so you could do it either in Application_Start or in an IInitializableModule.
What am i doing wrong:
I want to add the slash and also make the url lowercase..
this is my initialization module but url stays the same without slash and no lowercase:
Am i doing something wrong?
[InitializableModule]
public class RoutingInitialization : IInitializableModule
//Add initialization logic, this method is called once after CMS has been initialized
RouteConfig.RegisterRoutes(RouteTable.Routes);
WebApiConfig.Register(GlobalConfiguration.Configuration);
EPiServer.Web.Routing.ContentRoute.UseTrailingSlash = true;
EPiServer.Web.UrlSegment.UseLowerCaseSegments = true;
public void Preload(string[] parameters) { }
//Add uninitialization logic
How do I make sure UseTrailingSlash is set to true? Do I add the following to my global.asax Application_Start or is it something that has to be activated in web.config?
My mission is to make www.mysite.com/url to automaticly add a slash at the end, so it ends up www.mysite.com/url/ when the user tries to access it.
Thanks!
