Hello,
I would like to ask if EPiServer 7.5 supports right to left languages in edit mode?
I mean if TinyMCE editor supports it?
I was investigating this issue and found that there is "directionality" plugin in TinyMCE (included in episerver) but I believe that it is not working correctly. When I clicked Right To Left button and start typing EpiServer there was no difference. Typed letters were appearing on the right of the editor. When I tried use MSWord in RTL mode the new letters were appearing on the left side (which I believe is correct).
This might be confusing but please see the example for typing E, p, i, S, e, r, v, e, r
TinyMCE (rtl) - "EpiServer"
MS Word (rt) - "revreSipE"
Could you let me know if it is "by design"? Or maybe there are other options in TinyMCE or Episerver that I should use. I tested
it on EpiServer 6 R2 and EpiServer 7.5.
Regards,
Marcin Żak
