Problem with EPiTrace after upgrade
A while ago we updated a site with CMO and LiveMonitor to EPiServer 7.5, the upgrade was a little messy so the upgrade of LiveMonitor did not go by the standard way. I checked the upgrade script and run the sql command it was going to do and updated the nuget package.
Now I get a lot of these errors in the log so it seems like I have missed something, anyone got a clue what?
1.2.5 Unhandled exception in ASP.NET
System.Data.SqlClient.SqlException (0x80131904): Procedure or function 'epitraceRegisterVisit' expects parameter '@LanguageId', which was not supplied.
at System.Data.SqlClient.TdsParser.ThrowExceptionAndWarning(TdsParserStateObject stateObj, Boolean callerHasConnectionLock, Boolean asyncClose)
at System.Data.SqlClient.SqlCommand.FinishExecuteReader(SqlDataReader ds, RunBehavior runBehavior, String resetOptionsString)
at System.Data.SqlClient.SqlCommand.RunExecuteReaderTds(CommandBehavior cmdBehavior, RunBehavior runBehavior, Boolean returnStream, Boolean async, Int32 timeout, Task& task, Boolean asyncWrite, SqlDataReader ds)
at System.Data.SqlClient.SqlCommand.RunExecuteReader(CommandBehavior cmdBehavior, RunBehavior runBehavior, Boolean returnStream, String method, TaskCompletionSource`1 completion, Int32 timeout, Task& task, Boolean asyncWrite)
at System.Data.SqlClient.SqlCommand.InternalExecuteNonQuery(TaskCompletionSource`1 completion, String methodName, Boolean sendToPipe, Int32 timeout, Boolean asyncWrite)
at EPiServer.Trace.CMS.Services.TransferRepository.<>c__DisplayClass1.b__0()
at EPiServer.Data.Providers.SqlDatabaseHandler.<>c__DisplayClass4.b__3()
at EPiServer.Data.Providers.SqlDatabaseHandler.<>c__DisplayClass7`1.b__6()
at EPiServer.Trace.CMS.Services.TransferRepository.AddTransfer(VisitorMessageData hit)
at EPiServer.Trace.CMS.Web.TrackingHandler.ProcessTrackingRequest(HttpContextBase context)
ClientConnectionId:67048cbf-4b4f-4616-8424-a41b7d73e83c
#112530
Oct 29, 2014 15:59
I see now that the problem is that sometimes the url that is passed along to the tracing looks like this:
http://customerurl/TrackerHandler.ashx?pageId=3&amp;languageId=sv
Where there is &amp; instead of just &.
Any clues on why there is like that?
#113238
Nov 17, 2014 8:24
Are there not anyone else who have this problem?
#113931
Dec 01, 2014 21:23
#113936
Dec 02, 2014 7:00
Thanks Linus, I will try that, hope it works together with EPiServer CMO.
#113956
Dec 02, 2014 12:37
Linus, this is the only one I find on the nuget feed, or are there a special feed for AddOn's?
https://nuget.episerver.com/en/OtherPages/Package/?packageId=EPiServer.LiveMonitor
This is the old one
#113958
Dec 02, 2014 13:03
Yes, that's the package. Unfortunately, I was not aware of us having the CMO version of the package in the official feed, so the new version has the lowest number (1.0.2.716). We are investigating if we can just upgrade the version number of the new package and if this will enable us to simply upgrade the package or not. For now, you could try removing your existing version and explicitly installing the 1.0.2.716 version.
#113960
Dec 02, 2014 13:23
Ok, I have to wait then since CMO depends on "EPiServer.LiveMonitor (≥ 7.5.446.2 && < 8.0)" so I can not remove and replace with a lower number.
#113961
Dec 02, 2014 13:29
Ok, we will investagate and get back to you once we know if we can simply upgrade the version number.
#113962
Dec 02, 2014 13:30
Thanks!
#113964
Dec 02, 2014 13:37
Linus, any news on this?
#114366
Dec 11, 2014 7:48
We are still working on this and plan to have a working solution as well as good documention on how to do a fresh install as well as upgrading an existing solution within a few weeks.
#115388
Jan 14, 2015 12:34
Ok, thanks Linus!
#115390
Jan 14, 2015 12:59
