Image replacement
Hi, we have implemented MediaData content item and associated it with various image extensions, which all works fine.
My question is, if you want to replace an image, say you have a new version, how do you do that?  I've not been able to find any mechanism in the UI, but im new to 7.5 so improbably just missing where it is?
All i have been able to find is the actual image editor option, also tried dragging onto the existing one with a new one, which doesnt work either.
cheers!
#91456
Oct 06, 2014 13:03
Just upload a new file with the same file name as an existing item to the same directory and you should get a question if you want to replace the existing file. Also works for multiple uploads where at least one item already exists.
#91461
Oct 06, 2014 14:44
thanks.
#91463
Oct 06, 2014 16:25
