Episerver Find UnifiedSearch
Hi i am using UnifiedSearch, i used a Interface to define the Search and i want to returns the records with a image.
if i remove  CustomizeProjection it works, but i want to return the image also
The problem that i have is in line that get the results, it throwing a Exception
Message: "An error has occurred."
ExceptionMessage: "Object reference not set to an instance of an object."
ExceptionType: "System.NullReferenceException"
StackTrace: " at EPiServer.Find.UnifiedSearch.UnifiedSearchRegistry.GetProjectionForType(Type type) at EPiServer.Find.UnifiedSearch.UnifiedSearchRegistry.GetProjectionForType(Type type) at EPiServer.Find.UnifiedSearch.UnifiedSearchRegistry.GetRules(Type type) at System.Linq.Enumerable.WhereSelectEnumerableIterator`2.MoveNext() at
But i don't have idea what i am doing wrong
var results =
            SearchClient.Instance.UnifiedSearchFor(requestItem.SearchTerm)
            .GetResult();
public
 interface ISearchData     {          string SearchTitle { get;  }          string SearchText { get; }          string SearchSummary { get;  } string SearchHitUrl { get; }
Url SearchImage { get; set; }              }
public class FindInitialization : IInitializableModule
       public void Initialize(EPiServer.Framework.Initialization.InitializationEngine context)
            SearchClient.Instance.Conventions.UnifiedSearchRegistry.Add<>ISearchData>();
            SearchClient.Instance.Conventions.UnifiedSearchRegistry.ForInstanceOf<>ISearchData>().
               CustomizeProjection(x => x.ProjectImageUriFrom<>ISearchData>(c => GetPageImage(c.SearchImage)));
       private Uri GetPageImage(EPiServer.Url image)
           if (image != null)
               return image.Uri;
           return null;
#112557
Oct 30, 2014 6:32
I think it's easier to implement ISearchContent to your types and do your GetPageImage() in there.
#116160
Jan 25, 2015 19:21
