EPiServer CMS 6 R2 to 7.5 upgrade issue
We have upgraded our EPiServer CMS 6 R2 site to EPiServer CMS 7.5. After the upgrade I encounter the issue below when starting the site:
Can't find schema System.Collections.Generic.List`1[EPiServer.WorkflowFoundation.Workflows.ApproverItem] to deserialize against
Exception Details: System.Runtime.Serialization.SerializationException: Can't find schema System.Collections.Generic.List`1[EPiServer.WorkflowFoundation.Workflows.ApproverItem] to deserialize against
Source Error:
[No relevant source lines]
Source File: c:\Windows\Microsoft.NET\Framework64\v4.0.30319\Temporary ASP.NET Files\root\b2cfd15c\2258024c\App_global.asax.0.cs    Line: 0
Stack Trace:
[SerializationException: Can't find schema System.Collections.Generic.List`1[EPiServer.WorkflowFoundation.Workflows.ApproverItem] to deserialize against]
   EPiServer.Implementation.Serialization.ObjectReader.LoadObject() +542
   EPiServer.Implementation.Serialization.ObjectReader.LoadArray() +225
   EPiServer.Implementation.Serialization.ObjectReader.LoadObjectForType(Type type, ISchema serializedSchema, Type[] genericTypeParameters) +387
   EPiServer.Implementation.Serialization.ObjectReader.LoadObject() +369
   EPiServer.Implementation.Serialization.ObjectReader.LoadObjectForType(Type type, ISchema serializedSchema, Type[] genericTypeParameters) +458
   EPiServer.Implementation.SqlObjectStore.Load(Object id) +540
[ObjectStoreException: Exception on Load of 1a55c7e2-017a-441a-b208-7708d02f3858 in object store localdatabase.]
   EPiServer.Implementation.SqlObjectStore.Load(Object id) +1123
   EPiServer.Implementation.SqlObjectStore.RelatedItemsFrom(Object fromId, Boolean includeSubclasses, LoadMethod loadMethod) +762
[ObjectStoreException: Exception on Load of db0090ad-b10d-40ac-9407-cdc173815641 in object store localdatabase.]
   EPiServer.Implementation.SqlObjectStore.RelatedItemsFrom(Object fromId, Boolean includeSubclasses, LoadMethod loadMethod) +1548
   EPiServer.Implementation.SqlObjectStore.RelatedItemsFrom(Object fromId, LoadMethod loadMethod) +27
   EPiServer.Implementation.CacheObjectStore.RelatedItems(Object id, Boolean isFromRelation, LoadMethod loadMethod) +714
   EPiServer.Implementation.CacheObjectStore.RelatedItemsFrom(Object fromId) +108
   EPiServer.WorkflowFoundation.StorageProviders.ObjectStoreStorageProvider.LoadDefinitions() +825
   EPiServer.WorkflowFoundation.DefinitionHandler.LoadDefinitions() +87
   EPiServer.WorkflowFoundation.DefinitionHandler.get_WorkflowDefinitions() +121
   EPiServer.WorkflowFoundation.DefinitionHandler.ReloadDefinitions() +128
   EPiServer.WorkflowFoundation.AspNetWorkflowManager.CreateDefinitionHandler() +312
   EPiServer.WorkflowFoundation.AspNetWorkflowManager.Initialize(Boolean lazyLoading) +1869
   EPiServer.WorkflowFoundation.WorkflowSystem.StaticInitialization(WorkflowSettingsElement configElement) +927
   EPiServer.Framework.Initialization.ModuleNode.Execute(Action a, String key) +64
   EPiServer.Framework.Initialization.InitializationEngine.InitializeModules() +719
   EPiServer.Framework.Initialization.InitializationEngine.Initialize(HostType hostType) +168
   EPiServer.Framework.Initialization.InitializationModule.Initialize(HostType hostType) +285
   EPiServer.Framework.Initialization.InitializationModule.FrameworkInitialization(HostType hostType) +104
   EPiServer.Global..ctor() +110
   ASP.global_asax..ctor() in c:\Windows\Microsoft.NET\Framework64\v4.0.30319\Temporary ASP.NET Files\root\b2cfd15c\2258024c\App_global.asax.0.cs:0
   System.RuntimeTypeHandle.CreateInstance(RuntimeType type, Boolean publicOnly, Boolean noCheck, Boolean& canBeCached, RuntimeMethodHandleInternal& ctor, Boolean& bNeedSecurityCheck) +0
   System.RuntimeType.CreateInstanceSlow(Boolean publicOnly, Boolean skipCheckThis, Boolean fillCache, StackCrawlMark& stackMark) +159
   System.RuntimeType.CreateInstanceDefaultCtor(Boolean publicOnly, Boolean skipCheckThis, Boolean fillCache, StackCrawlMark& stackMark) +256
   System.Activator.CreateInstance(Type type, Boolean nonPublic) +127
   System.RuntimeType.CreateInstanceImpl(BindingFlags bindingAttr, Binder binder, Object[] args, CultureInfo culture, Object[] activationAttributes, StackCrawlMark& stackMark) +14259449
   System.Activator.CreateInstance(Type type, BindingFlags bindingAttr, Binder binder, Object[] args, CultureInfo culture, Object[] activationAttributes) +200
   System.Activator.CreateInstance(Type type, BindingFlags bindingAttr, Binder binder, Object[] args, CultureInfo culture) +28
   System.Web.HttpRuntime.CreateNonPublicInstance(Type type, Object[] args) +83
   System.Web.HttpApplicationFactory.GetSpecialApplicationInstance(IntPtr appContext, HttpContext context) +312
   System.Web.Hosting.PipelineRuntime.InitializeApplication(IntPtr appContext) +475
   System.Web.HttpRuntime.FirstRequestInit(HttpContext context) +12979668
   System.Web.HttpRuntime.EnsureFirstRequestInit(HttpContext context) +159
   System.Web.HttpRuntime.ProcessRequestNotificationPrivate(IIS7WorkerRequest wr, HttpContext context) +12819261
#112063
Oct 22, 2014 10:55
Are you upgrading directly from 6 R2 to 7.5? I believe we don't support that. You will need to upgrade to CMS 7 first, then 7.5
Regards.
/Q
#112069
Oct 22, 2014 12:49
