ChildrenCssClass not working
I'm just wondering if there is a reason why the value I'm setting in ChildrenCssClass isn't being rendered. We're using version 7.10
@Html.PropertyFor(m => m.CurrentPage.ButtonArea, new { CssClass = "row buttons", ChildrenCustomTagName = "div", ChildrenCssClass = "small-12 medium-6 xlarge-3 columns" })
Rather than seeing this:
I see this
Cheers
Jonathan.
#111993
Oct 22, 2014 1:12
I'm guessing you are using the "AlloyContentAreaRenderer". This override "GetContentAreaItemCssClass".
Alloy version:
        protected override string GetContentAreaItemCssClass(HtmlHelper htmlHelper, ContentAreaItem contentAreaItem)
            var tag = GetContentAreaItemTemplateTag(htmlHelper, contentAreaItem);
            return string.Format("block {0} {1} {2}", GetTypeSpecificCssClasses(contentAreaItem, ContentRepository), GetCssClassForTag(tag), tag);
Base version:
    protected virtual string GetContentAreaItemCssClass(HtmlHelper htmlHelper, ContentAreaItem contentAreaItem)
      return htmlHelper.ViewContext.ViewData["childrencssclass"] as string;
As you can see, the alloy version does not use the childrencssclass. You can add it though, like so (not tested):
            return string.Format("block {0} {1} {2} {3}", GetTypeSpecificCssClasses(contentAreaItem, ContentRepository), GetCssClassForTag(tag), tag, htmlHelper.ViewContext.ViewData["childrencssclass"] as string);
#111997
Oct 22, 2014 9:07
I agree to Per Magnes solution.
I works as expected
#112002
Oct 22, 2014 9:53
Thank you, that was the issue.
#112119
Oct 23, 2014 0:11
