Add/Remove items from the 'Tools' menu in edit mode
I'm sure I found something on this via Google earlier, but I can't remember the search term. all I want to do is add/remove items from the Edit menu when viewing all properties in Edit mode:
sample
This is easy, right?
#112107
Oct 22, 2014 18:24
Fix your image, and answers shall (maybe) be given! :-)
#112116
Oct 22, 2014 23:20
Maybe I should raise a post about adding images to posts!
The button I mean is available in edit mode when you click the 'All Properties' button.
By default it's a drop-down called Tools, with the Items Dynamic Properties, Language Settings, Manage Expiration and Archiving, Permanently Mark as Being Edited, and Start a Workflow.
#112138
Oct 23, 2014 9:59
Eric Herlitz - Jun 08, 2023 20:50
The links have changed
https://world.optimizely.com/blogs/Duong-Nguyen/Dates/2013/12/Custom-views-and-plugin-areas-in-EPiServer-75/
https://world.optimizely.com/blogs/Linus-Ekstrom/Dates/2014/4/Adding-custom-views-to-your-content/
Per,
Those are what I was after, thanks.
Mark
#112172
Oct 23, 2014 17:42
The posts linked is a good example for adding items to the tools menu, but I would like to hide the "Language Settings" item from the menu. Is this possible somehow? Does anybody know how?
#113357
Nov 19, 2014 8:49
Has anyone worked out how items can be removed / hidden from the Tools menu (based on user's group membership for example)?
#120287
Apr 14, 2015 16:14
