Web.config parser error after 7.6 update
After update from 7.5 to 7.6 i get the following error when i run my project:
Configuration ErrorDescription: An error occurred during the processing of a configuration file required to service this request. Please review the specific error details below and modify your configuration file appropriately.
Parser Error Message: Exception has been thrown by the target of an invocation.
Source Error:
Line 188:
If i comment the line in web.config and use Sql as role/membership-provider it works.
Web.config:
Application error log:
Event code: 3008
Event message: A configuration error has occurred.
Event time: 2014-10-01 13:48:25
Event time (UTC): 2014-10-01 11:48:25
Event ID: 5887c030f42b49eba568f05e9240f9b1
Event sequence: 1
Event occurrence: 1
Event detail code: 0
Application information:
    Application domain: /LM/W3SVC/6/ROOT-7-130566377036628360
    Trust level: Full
    Application Virtual Path: /
    Application Path: C:\projects\proj\proj\
    Machine name: MFE
Process information:
    Process ID: 4052
    Process name: w3wp.exe
    Account name: IIS APPPOOL\proj
Exception information:
    Exception type: InvalidOperationException
    Exception message: The pre-application start initialization method Start on type WebMatrix.WebData.PreApplicationStartCode threw an exception with the following error message: Exception has been thrown by the target of an invocation. (C:\projects\proj\proj\web.config line 187).
   at System.Web.Compilation.BuildManager.InvokePreStartInitMethodsCore(ICollection`1 methods, Func`1 setHostingEnvironmentCultures)
   at System.Web.Compilation.BuildManager.InvokePreStartInitMethods(ICollection`1 methods)
   at System.Web.Compilation.BuildManager.CallPreStartInitMethods(String preStartInitListPath, Boolean& isRefAssemblyLoaded)
   at System.Web.Compilation.BuildManager.ExecutePreAppStart()
   at System.Web.Hosting.HostingEnvironment.Initialize(ApplicationManager appManager, IApplicationHost appHost, IConfigMapPathFactory configMapPathFactory, HostingEnvironmentParameters hostingParameters, PolicyLevel policyLevel, Exception appDomainCreationException)
   at System.Web.Configuration.ProvidersHelper.InstantiateProvider(ProviderSettings providerSettings, Type providerType)
   at System.Web.Configuration.ProvidersHelper.InstantiateProviders(ProviderSettingsCollection configProviders, ProviderCollection providers, Type providerType)
   at System.Web.Security.Membership.InitializeSettings(Boolean initializeGeneralSettings, RuntimeConfig appConfig, MembershipSection settings)
   at System.Web.Security.Membership.Initialize()
   at System.Web.Security.Membership.get_Providers()
   at WebMatrix.WebData.WebSecurity.PreAppStartInit()
   at WebMatrix.WebData.PreApplicationStartCode.Start()
   at System.RuntimeTypeHandle.CreateInstance(RuntimeType type, Boolean publicOnly, Boolean noCheck, Boolean& canBeCached, RuntimeMethodHandleInternal& ctor, Boolean& bNeedSecurityCheck)
   at System.RuntimeType.CreateInstanceSlow(Boolean publicOnly, Boolean skipCheckThis, Boolean fillCache, StackCrawlMark& stackMark)
   at System.RuntimeType.CreateInstanceDefaultCtor(Boolean publicOnly, Boolean skipCheckThis, Boolean fillCache, StackCrawlMark& stackMark)
   at System.Activator.CreateInstance(Type type, Boolean nonPublic)
   at System.Activator.CreateInstance(Type type)
Activation error occurred while trying to get instance of type SynchronizingUserService, key ""
   at EPiServer.ServiceLocation.ServiceLocatorImplBase.GetInstance(Type serviceType, String key)
   at EPiServer.ServiceLocation.ServiceLocatorImplBase.GetInstance[TService]()
   at EPiServer.Security.WindowsMembershipProvider..ctor()
StructureMap Exception Code:  207
Internal exception while creating Instance 'a0ce6497-721d-4aa5-8ecb-39df9b2dc90f' of PluginType EPiServer.Security.SynchronizingUserService.  Check the inner exception for more details.
   at StructureMap.Pipeline.ConstructorInstance.Build(Type pluginType, BuildSession session, IInstanceBuilder builder)
   at StructureMap.Pipeline.Instance.createRawObject(Type pluginType, BuildSession session)
   at StructureMap.Pipeline.Instance.Build(Type pluginType, BuildSession session)
   at StructureMap.Pipeline.ObjectBuilder.Resolve(Type pluginType, Instance instance, BuildSession session)
   at StructureMap.BuildSession.CreateInstance(Type pluginType, Instance instance)
   at StructureMap.BuildSession.CreateInstance(Type pluginType)
Activation error occurred while trying to get instance of type ServiceAccessor`1, key ""
   at EPiServer.Security.SynchronizingUserService..ctor()
   at lambda_method(Closure , IArguments )
   at StructureMap.Construction.BuilderCompiler.FuncCompiler`1.<>c__DisplayClass2.b__0(IArguments args)
   at StructureMap.Construction.InstanceBuilder.BuildInstance(IArguments args)
StructureMap Exception Code:  202
No Default Instance defined for PluginFamily EPiServer.ServiceLocation.ServiceAccessor`1[[EPiServer.DataAccess.WindowsProviderDB, EPiServer, Version=7.14.0.0, Culture=neutral, PublicKeyToken=8fe83dea738b45b7]], EPiServer.Framework, Version=7.14.0.0, Culture=neutral, PublicKeyToken=8fe83dea738b45b7
   at StructureMap.BuildSession.<.ctor>b__0(Type t)
   at StructureMap.Util.Cache`2.get_Item(KEY key)
Request information:
    Request URL: http://localhost:17331/
    Request path: /
    User host address: ::1
    User:
    Is authenticated: False
    Authentication Type:
    Thread account name: IIS APPPOOL\proj
Thread information:
    Thread ID: 108
    Is impersonating: False
    Stack trace:    at System.Web.Compilation.BuildManager.InvokePreStartInitMethodsCore(ICollection`1 methods, Func`1 setHostingEnvironmentCultures)
Custom event details:
I would appreciate any thoughts about this.
#91282
Oct 01, 2014 14:24
Seems like the collapse function in "Insert code" doesn't work.
Event code: 3008
Event sequence: 1
Event occurrence: 1
    Trust level: Full
    Machine name: machinename
    Process ID: 4052
    Request path: /
    User:
Thread information:
    Thread ID: 108
#91283
Edited, Oct 01, 2014 14:26
It seems like the code in WebMatrix.WebData.PreApplicationStartCode accesses the membership provider very early in the application startup (it has probably a PreApplicationStartMethod assembly attribute). And since the WindowsMembershipProvider has dependencys that it expects from IOC container it fails to instantiate (since at this early stage the IOC container is not poulated).
I will report a bug and see if we can get rid of IOC dependency from the provider.
But for you: Do you have a nuget package WebMatrix.WebData, if so do you need it, it seems to have been replaced, see https://www.nuget.org/packages/WebMatrix.WebData/??
#91292
Oct 01, 2014 16:45
Fix is out in CMS.Core 7.15:
http://world.episerver.com/Documentation/Release-Notes/ReleaseNote/?releaseNoteId=118068
#112231
Oct 24, 2014 16:30
