How to manage website languages programatically
Is it possible to enable/disable website languages in code not using Admin UI?
For example to disable 'sv' language which is enabled by create empty db script (EPiServerRelease75.sql).
#80684
Jan 29, 2014 16:43
This is basically what EPiServer do in Admin Mode when activating languages:
var repository = LanguageBranch.LanguageBranchRepository;
LanguageBranch languageBranch = repository.Load("sv");
var copiedBranch = new LanguageBranch(languageBranch.ID, languageBranch.LanguageID, languageBranch.Name, languageBranch.SortIndex, languageBranch.RawIconPath, languageBranch.URLSegment, true);
repository.Save(copiedBranch);
#80689
Edited, Jan 29, 2014 23:44
Aha. Interesting approach to bypass readonly "Enabled" property :). Thanks.
But it doesn't work in my code. I got "the wait operation timeout" on repository.Save(copiedBranch);
The same error I get when trying to languageBranch.Delete().
Do you have an idea why it works in Admin UI mode but doesn't work for me?
#80701
Jan 30, 2014 9:49
It worked for me and I copied my code directly in my post.
Where/when are you trying to run your code?
#80702
Jan 30, 2014 9:51
I run it from Initialization module on the site startup.
May be it is the reason?
[InitializableModule]
[ModuleDependency(typeof(InitializationModule))]
#80736
Jan 30, 2014 16:53
That's exactly what I'm doing:
[ModuleDependency(typeof(Web.InitializationModule))]
public class MyInitializer : IInitializableModule
private const string RouteName = "LogoutRedirect";
var languageBranch = repository.Load("da");
public void Preload(string[] parameters) { }
#80752
Jan 31, 2014 8:23
Thanks. The problem was on my side.
We do a set of operations (creating some initial content) using transactionScope and
repository.Save(copiedBranch) fails with timeout in the in the end of our scope
(which is completed succesfully without this language change).
#80774
Jan 31, 2014 14:50
Great, hope you find a solution on the transactionScope issue.
#80775
Jan 31, 2014 14:55
