Multiple languages for files
I recently upgraded to 7.5 and the new media system looks very promising. Now I'm rewriting old code (VPP-based) to use the new media system. It is indeed good news to be able to have strongly-typed access to custom properties, access rights etc.
My question is if the new system can handle multiple language versions of a media file? The "Tools -> Language Settings" is greyed out when editing a media file.
(Previously I handled localization of files by uploading several files following a given naming convention (xxxx-en.pdf, xxxx-se.pdf etc) and applied logic in code to list/group the resources accordingly upon output. Works, but kind of messy...)
#80651
Jan 28, 2014 14:53
Unfortunately, the current implementation of media does not implement language versions of the same item at the moment so you will have to make a solution similar to the VPP one. There has been, and still is a debate ongoing about the pros and cons of having media language neutral so there might be changes upcoming in this area in the future. But as said above, for now media files are language agnostic and not localizable.
#80652
Jan 28, 2014 15:38
Ah, good to know, then I can at least stop searching for ways to activate it :)
#80657
Jan 28, 2014 17:26
In theory it might be possible to implement ILocalizable on your media types. What you would need to do then is replace the registered media routes so they include a language segment.
However I have not verified that everything works as expected (e.g. each part of the UI) but in theory it should work....
#80671
Jan 29, 2014 10:06
Hi Johan and Linus, do you have any update on this? Or will it stay in it's current shape forever?
#90487
Sep 10, 2014 14:53
I have not heard anything from PM direction about changing current behaviour.
#90488
Sep 10, 2014 14:57
Ok, I'll have a look at your local media provider and see if that could point me in the right direction.
#90489
Sep 10, 2014 15:08
