About VppMigrationTool error
site has upgraded from cms6r2=>cms7=>cms7.5
When i use VppMigrationTool convert vpp show error
Exception has been thrown by the target of an invocation.
at System.RuntimeMethodHandle.InvokeMethod(Object target, Object[] arguments, Signature sig, Boolean constructor)
at System.Reflection.RuntimeMethodInfo.UnsafeInvokeInternal(Object obj, Object[] parameters, Object[] arguments)
at System.Reflection.RuntimeMethodInfo.Invoke(Object obj, BindingFlags invokeAttr, Binder binder, Object[] parameters, CultureInfo culture)
at EPiServer.PlugIn.PlugInRuntime.Call(TypesWithState typeWithState, String methodName)
at EPiServer.PlugIn.PlugInRuntime.Call(String methodName)
at EPiServer.PlugIn.PlugInRuntime.Start(Boolean reset)
at EPiServer.Initialization.PlugInInitialization.Initialize(InitializationEngine context)
at EPiServer.Framework.Initialization.ModuleNode.Execute(Action a, String key)
at EPiServer.Framework.Initialization.InitializationEngine.InitializeModules()
at EPiServer.Framework.Initialization.InitializationEngine.Initialize(HostType hostType)
at EPiServer.Framework.Initialization.InitializationModule.Initialize(HostType hostType)
at EPiServer.Framework.Initialization.InitializationModule.FrameworkInitialization(HostType hostType)
at VppMigrationTool.Util.SiteProxy.InitalizeEPiServer(String webConfigPath) in d:\Builds\132\EPiServerCMS Modules\VppMigrationTool\Sources\C\TFS\VppMigrationTool\Util\SiteProxy.cs:line 52
at VppMigrationTool.Util.SiteProxy.Initialize(String destinationPath, String virtualDirectory) in d:\Builds\132\EPiServerCMS Modules\VppMigrationTool\Sources\C\TFS\VppMigrationTool\Util\SiteProxy.cs:line 129
at VppMigrationTool.Converter.get_RuntimeProxyWrapper() in d:\Builds\132\EPiServerCMS Modules\VppMigrationTool\Sources\C\TFS\VppMigrationTool\Converter.cs:line 52
at VppMigrationTool.Converter.FillSiteData() in d:\Builds\132\EPiServerCMS Modules\VppMigrationTool\Sources\C\TFS\VppMigrationTool\Converter.cs:line 101
--- Inner exception ---
Operation is not valid due to the current state of the object.
at System.Web.Hosting.HostingEnvironment.RegisterVirtualPathProvider(VirtualPathProvider virtualPathProvider)
my web.config is
<configuration>
<configSections>
<section name="microsoft.web.services3" type="Microsoft.Web.Services3.Configuration.WebServicesConfiguration, Microsoft.Web.Services3, Version=3.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35" />
<section name="workflowRuntime" type="System.Workflow.Runtime.Configuration.WorkflowRuntimeSection, System.Workflow.Runtime, Version=3.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35" />
<section name="wftools.services.common.ado" type="WFTools.Services.Common.Ado.Configuration.CommonAdoProviderSettings,EPiServer.WFTools.Services" />
<section name="wftools.services.persistence.ado" type="WFTools.Services.Persistence.Ado.Configuration.PersistenceAdoProviderSettings,EPiServer.WFTools.Services" />
<section name="wftools.services.tracking.ado" type="WFTools.Services.Tracking.Ado.Configuration.TrackingAdoProviderSettings,EPiServer.WFTools.Services" />
<section name="episerver" type="EPiServer.Configuration.EPiServerSection, EPiServer.Configuration, Version=7.5.394.2, Culture=neutral, PublicKeyToken=8fe83dea738b45b7" restartOnExternalChanges="true" />
<section name="staticFile" type="EPiServer.Framework.Configuration.StaticFileSection, EPiServer.Framework" allowLocation="true" />
<section name="episerver.baseLibrary" allowDefinition="MachineToApplication" allowLocation="false" type="EPiServer.BaseLibrary.ConfigurationHandler,EPiServer.BaseLibrary" />
<section name="episerver.basicAuthentication" type="EPiServer.Configuration.BasicAuthenticationSection, EPiServer.Configuration" allowLocation="true" />
<sectionGroup name="episerverModules" />
<section name="episerver.shell" type="EPiServer.Shell.Configuration.EPiServerShellSection, EPiServer.Shell" />
<section name="episerver.dataStore" type="EPiServer.Data.Configuration.EPiServerDataStoreSection, EPiServer.Data" />
<section name="episerver.framework" type="EPiServer.Framework.Configuration.EPiServerFrameworkSection, EPiServer.Framework" restartOnExternalChanges="true" />
<section name="episerver.search" type="EPiServer.Search.Configuration.SearchSection, EPiServer.ApplicationModules" />
<sectionGroup name="elmah">
<section name="security" requirePermission="false" type="Elmah.SecuritySectionHandler, Elmah" />
<section name="errorLog" requirePermission="false" type="Elmah.ErrorLogSectionHandler, Elmah" />
<section name="errorMail" requirePermission="false" type="Elmah.ErrorMailSectionHandler, Elmah" />
<section name="errorFilter" requirePermission="false" type="Elmah.ErrorFilterSectionHandler, Elmah" />
</sectionGroup>
<section name="mailchimpSettings" requirePermission="false" type="Avantime.CMS.Mailchimp.Core.Configuration.MailChimpSettings, Avantime.CMS.Mailchimp" />
<section name="avantime.metadata" type="Avantime.SEO.Configuration.MetaDataSection, Avantime.SEO.EPi7, Version=0.0.0.0, Culture=neutral" />
<section name="TradeDoublerConfig" type="SKTF.Configuration.TradeDoublerConfig" />
<section name="MembershipFeeConfiguration" type=" SKTF.Configuration.MembershipFeeConfiguration" />
<section name="routeMappingSettings" type="SKTF.Web.ConfigSections.RouteMappingSection" />
<section name="sktf.initialization" type="SKTF.Configuration.InitializationConfiguration, SKTF.Configuration" />
<section name="sktf.network" type="SKTF.Configuration.NetworkConfiguration" />
<section name="ApsisConfig" type="Avantime.Apsis.Configuration.ApsisConfiguration, Avantime.Apsis" />
<section name="avantime.messageHub" type="Avantime.MessageHub.Configuration.MessageHubConfiguration, Avantime.MessageHub" />
<section name="messageHubMappings" type="Avantime.MessageHub.Configuration.MessageHubMappings, Avantime.MessageHub" />
<section name="resizer" type="ImageResizer.ResizerSection,ImageResizer" requirePermission="false" />
<section name="RequestReduce" type="RequestReduce.Configuration.RequestReduceConfigSection, RequestReduce" requirePermission="false" />
<section name="dotless" type="dotless.Core.configuration.DotlessConfigurationSectionHandler, dotless.Core" />
<section name="entityFramework" type="System.Data.Entity.Internal.ConfigFile.EntityFrameworkSection, EntityFramework, Version=4.4.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" requirePermission="false" />
<section name="CustomizableXhtmlPropertyConfiguration" type="SKTF.Configuration.CustomizableXhtmlPropertyConfiguration, SKTF.Configuration, Version=1.0.0.0, Culture=neutral" />
<section name="episerver.packaging" type="EPiServer.Packaging.Configuration.EPiServerPackagingSection, EPiServer.Packaging" />
<section name="episerver.search.indexingservice" type="EPiServer.Search.IndexingService.Configuration.IndexingServiceSection, EPiServer.Search.IndexingService" />
</configSections>
<avantime.metadata>
<adapters>
<clear />
<add name="PageDataAdapter" type="Avantime.SEO.Adapters.PageDataAdapter, Avantime.SEO.EPi7, Version=0.0.0.0, Culture=neutral" title="Title" facebook-title="FacebookTitle,Title,Heading,PageName" description="Description,MainIntro" description-htmlFallback="OccupationDescription,MainBody" facebook-description="FacebookDescription,Description,MainIntro" facebook-fallbackImagePath="/images/facebookfallbackimage.png" />
</adapters>
<renderers>
<clear />
<add name="MandatoryRenderer" type="Avantime.SEO.MetaRender.MandatoryMetaRender, Avantime.SEO.EPi7" />
<add name="FacebookRenderer" type="Avantime.SEO.MetaRender.FacebookMetaRender, Avantime.SEO.EPi7" />
</renderers>
</avantime.metadata>
<episerver configSource="episerver.config" />
<staticFile expirationTime="0.0:0:1" />
<episerver.baseLibrary>
<classFactories>
<add type="EPiServer.Implementation.DefaultBaseLibraryFactory, EPiServer.Implementation" id="ContentChannelFactory">
<register type="EPiServer.ContentChannels.ContentChannelAdministration, EPiServer" mappedType="EPiServer.ContentChannels.ObjectStoreContentChannelAdministration, EPiServer" />
<register type="EPiServer.BaseLibrary.IContentChannelHandler, EPiServer" mappedType="EPiServer.ContentChannels.ContentChannelHandler, EPiServer" />
</add>
<add type="EPiServer.Core.PropertyControlClassFactory, EPiServer" id="PropertyControlFactory">
</add>
</classFactories>
</episerver.baseLibrary>
<workflowRuntime EnablePerformanceCounters="false">
<Services>
<add type="System.Workflow.Runtime.Hosting.DefaultWorkflowSchedulerService, System.Workflow.Runtime, Version=3.0.00000.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35" maxSimultaneousWorkflows="5" />
<add type="System.Workflow.Runtime.Hosting.SharedConnectionWorkflowCommitWorkBatchService, System.Workflow.Runtime, Version=3.0.00000.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35" />
<add type="System.Workflow.Runtime.Hosting.SqlWorkflowPersistenceService, System.Workflow.Runtime, Version=3.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35" UnloadOnIdle="true" />
</Services>
</workflowRuntime>
<runtime>
<assemblyBinding>
<dependentAssembly />
</assemblyBinding>
<assemblyBinding xmlns="urn:schemas-microsoft-com:asm.v1">
<dependentAssembly>
<assemblyIdentity name="EPiServer.ApplicationModules" publicKeyToken="8fe83dea738b45b7" culture="neutral" />
<bindingRedirect oldVersion="0.0.0.0-7.5.409.0" newVersion="7.5.409.0" />
</dependentAssembly>
<dependentAssembly>
<assemblyIdentity name="EPiServer.Data.Cache" publicKeyToken="8fe83dea738b45b7" culture="neutral" />
<dependentAssembly>
<assemblyIdentity name="EPiServer.Data" publicKeyToken="8fe83dea738b45b7" culture="neutral" />
<dependentAssembly>
<assemblyIdentity name="EPiServer.Events" publicKeyToken="8fe83dea738b45b7" culture="neutral" />
<dependentAssembly>
<assemblyIdentity name="EPiServer.Framework" publicKeyToken="8fe83dea738b45b7" culture="neutral" />
<dependentAssembly>
<assemblyIdentity name="EPiServer.Licensing" publicKeyToken="8fe83dea738b45b7" culture="neutral" />
<dependentAssembly>
<assemblyIdentity name="EPiServer.Shell" publicKeyToken="8fe83dea738b45b7" culture="neutral" />
<dependentAssembly>
<assemblyIdentity name="System.ComponentModel.Composition" publicKeyToken="8fe83dea738b45b7" culture="neutral" />
<bindingRedirect oldVersion="1.0.0.0-2009.22.10.0" newVersion="2009.22.10.0" />
<dependentAssembly>
<assemblyIdentity name="System.Web.Mvc" publicKeyToken="31bf3856ad364e35" culture="neutral" />
<bindingRedirect oldVersion="1.0.0.0-3.0.0.0" newVersion="4.0.0.0" />
<dependentAssembly>
<assemblyIdentity name="ElektroPost.Licensing" publicKeyToken="8fe83dea738b45b7" culture="neutral" />
<bindingRedirect oldVersion="5.2.375.0-6.65535.65535.65535" newVersion="6.1.379.0" />
<dependentAssembly>
<assemblyIdentity name="EPiServer.BaseLibrary" publicKeyToken="8fe83dea738b45b7" culture="neutral" />
<dependentAssembly>
<assemblyIdentity name="EPiServer.Configuration" publicKeyToken="8fe83dea738b45b7" culture="neutral" />
<dependentAssembly>
<assemblyIdentity name="EPiServer" publicKeyToken="8fe83dea738b45b7" culture="neutral" />
<dependentAssembly>
<assemblyIdentity name="EPiServer.Enterprise" publicKeyToken="8fe83dea738b45b7" culture="neutral" />
<dependentAssembly>
<assemblyIdentity name="EPiServer.ImageLibrary" publicKeyToken="8fe83dea738b45b7" culture="neutral" />
<dependentAssembly>
<assemblyIdentity name="EPiServer.Implementation" publicKeyToken="8fe83dea738b45b7" culture="neutral" />
<dependentAssembly>
<assemblyIdentity name="EPiServer.Legacy4" publicKeyToken="8fe83dea738b45b7" culture="neutral" />
<dependentAssembly>
<assemblyIdentity name="EPiServer.LinkAnalyzer" publicKeyToken="8fe83dea738b45b7" culture="neutral" />
<dependentAssembly>
<assemblyIdentity name="EPiServer.Log.Analyzers" publicKeyToken="8fe83dea738b45b7" culture="neutral" />
<dependentAssembly>
<assemblyIdentity name="EPiServer.Log.Core" publicKeyToken="8fe83dea738b45b7" culture="neutral" />
<dependentAssembly>
<assemblyIdentity name="EPiServer.Lucene" publicKeyToken="8fe83dea738b45b7" culture="neutral" />
<dependentAssembly>
<assemblyIdentity name="EPiServer.UI" publicKeyToken="8fe83dea738b45b7" culture="neutral" />
<dependentAssembly>
<assemblyIdentity name="EPiServer.Web.WebControls" publicKeyToken="8fe83dea738b45b7" culture="neutral" />
<dependentAssembly>
<assemblyIdentity name="EPiServer.WorkflowFoundation" publicKeyToken="8fe83dea738b45b7" culture="neutral" />
<dependentAssembly>
<assemblyIdentity name="EPiServer.XForms" publicKeyToken="8fe83dea738b45b7" culture="neutral" />
<dependentAssembly>
<assemblyIdentity name="log4net" publicKeyToken="1b44e1d426115821" culture="neutral" />
<bindingRedirect oldVersion="1.0.0.0-1.65535.65535.65535" newVersion="1.2.10.0" />
<dependentAssembly>
<assemblyIdentity name="Microsoft.Web.Services3" publicKeyToken="31bf3856ad364e35" culture="neutral" />
<bindingRedirect oldVersion="3.0.0.0-3.65535.65535.65535" newVersion="3.0.0.0" />
<dependentAssembly>
<assemblyIdentity name="System.Web.DataVisualization" publicKeyToken="31bf3856ad364e35" culture="neutral" />
<bindingRedirect oldVersion="3.5.0.0-4.65535.65535.65535" newVersion="4.0.0.0" />
<dependentAssembly>
<assemblyIdentity name="dotless.Core" publicKeyToken="96b446c9e63eae34" culture="neutral" />
<bindingRedirect oldVersion="0.0.0.0-1.3.1.0" newVersion="1.3.1.0" />
<probing privatePath="modulesbin" />
<dependentAssembly>
<assemblyIdentity name="System.ComponentModel.Composition" publicKeyToken="31bf3856ad364e35" culture="neutral" />
<bindingRedirect oldVersion="1.0.0.0-2009.22.10.0" newVersion="4.0.0.0" />
<dependentAssembly>
<assemblyIdentity name="System.Web.Extensions" publicKeyToken="31bf3856ad364e35" culture="neutral" />
<bindingRedirect oldVersion="1.0.61025.0" newVersion="4.0.0.0" />
<dependentAssembly>
<assemblyIdentity name="Castle.Core" publicKeyToken="407dd0808d44fbdc" culture="neutral" />
<bindingRedirect oldVersion="3.0.0.0-3.65535.65535.65535" newVersion="3.2.0.0" />
<dependentAssembly>
<assemblyIdentity name="Castle.Windsor" publicKeyToken="407dd0808d44fbdc" culture="neutral" />
<dependentAssembly>
<assemblyIdentity name="EPiServer.Search.IndexingService" publicKeyToken="8fe83dea738b45b7" culture="neutral" />
<bindingRedirect oldVersion="1.0.517.262-7.65535.65535.65535" newVersion="7.5.394.2" />
<dependentAssembly>
<assemblyIdentity name="StructureMap" publicKeyToken="e60ad81abae3c223" culture="neutral" />
<bindingRedirect oldVersion="0.0.0.0-2.65535.65535.65535" newVersion="2.6.4.0" />
<dependentAssembly>
<assemblyIdentity name="Newtonsoft.Json" publicKeyToken="30ad4fe6b2a6aeed" culture="neutral" />
<bindingRedirect oldVersion="0.0.0.0-4.65535.65535.65535" newVersion="4.5.0.0" />
</assemblyBinding>
</runtime>
<!-- Connection string info is stored in a separate file -->
<connectionStrings configSource="connectionStrings.config" />
<!-- SMTP Settings for ASP.NET 2.0 Mail classes. -->
<system.net>
<mailSettings>
<smtp deliveryMethod="SpecifiedPickupDirectory">
<specifiedPickupDirectory pickupDirectoryLocation="d:\temp\" />
</smtp>
<!-- Common usage is to use other network existing mail server other than
IIS Virtual SMTP Server.
In such cases use the commented settings below with your server
location and authentication credentials.
</mailSettings>
</system.net>
<system.web>
<machineKey validationKey="517D6B63B475CC4CC2611282EEB89AF289985995C2C758D0F017A57220ACFFD684C7A83396E09348A07EB14C59A7EDB36AA2BAF7420ED68F53CD28589F0E297C" decryptionKey="3642E73B2F44437EFA13CD9B1615918F2CA738AD67E197DC209E72DA4FA43531" validation="SHA1" decryption="AES" />
<roleManager enabled="true" defaultProvider="MultiplexingRoleProvider" cacheRolesInCookie="true">
<providers>
<clear />
<!-- Comment the following lines when running on oracle. -->
<add name="MultiplexingRoleProvider" type="EPiServer.Security.MultiplexingRoleProvider, EPiServer" provider1="FaITRoleProvider" provider2="WindowsRoleProvider" providerMap1="FaITMembershipProvider" providerMap2="WindowsMembershipProvider" />
<add name="WindowsRoleProvider" applicationName="EPiServerSample" type="EPiServer.Security.WindowsRoleProvider, EPiServer" />
<add name="FaITRoleProvider" connectionStringName="EPiServerDB" applicationName="EPiServerSample" type="SKTF.Web.Security.FaITRoleProvider" />
<add name="SqlServerRoleProvider" connectionStringName="EPiServerDB" applicationName="EPiServerSample" type="System.Web.Security.SqlRoleProvider, System.Web, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a" />
</providers>
</roleManager>
<membership defaultProvider="MultiplexingMembershipProvider" userIsOnlineTimeWindow="10">
<providers>
<clear />
<add name="MultiplexingMembershipProvider" type="EPiServer.Security.MultiplexingMembershipProvider, EPiServer" provider1="FaITMembershipProvider" provider2="WindowsMembershipProvider" />
<add name="WindowsMembershipProvider" type="EPiServer.Security.WindowsMembershipProvider, EPiServer" deletePrefix="BUILTIN\" searchByEmail="true" />
<add name="SqlServerMembershipProvider" type="System.Web.Security.SqlMembershipProvider, System.Web, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a" connectionStringName="EPiServerDB" requiresQuestionAndAnswer="false" applicationName="EPiServerSample" requiresUniqueEmail="true" passwordFormat="Hashed" maxInvalidPasswordAttempts="5" minRequiredPasswordLength="6" minRequiredNonalphanumericCharacters="0" passwordAttemptWindow="10" passwordStrengthRegularExpression="" />
<add name="FaITMembershipProvider" type="SKTF.Web.Security.FaITMembershipProvider" connectionStringName="EPiServerDB" requiresQuestionAndAnswer="false" applicationName="EPiServerSample" requiresUniqueEmail="true" passwordFormat="Hashed" maxInvalidPasswordAttempts="10" minRequiredPasswordLength="6" minRequiredNonalphanumericCharacters="0" passwordAttemptWindow="10" passwordStrengthRegularExpression="" />
</providers>
</membership>
<profile enabled="true" defaultProvider="SqlProfile" automaticSaveEnabled="true">
<properties>
<add name="UserID" type="System.String" />
<add name="VerifyCode" type="System.String" />
<add name="Address" type="System.String" />
<add name="ZipCode" type="System.String" />
<add name="Locality" type="System.String" />
<add name="Email" type="System.String" />
<add name="FirstName" type="System.String" />
<add name="LastName" type="System.String" />
<add name="Language" type="System.String" />
<add name="Country" type="System.String" />
<add name="Company" type="System.String" />
<add name="Title" type="System.String" />
<add name="SubscriptionInfo" type="EPiServer.Personalization.SubscriptionInfo, EPiServer" />
<add name="CustomExplorerTreePanel" type="System.String" />
<add name="FileManagerFavourites" type="System.Collections.Generic.List`1[System.String]" />
<add name="EditTreeSettings" type="EPiServer.Personalization.GuiSettings, EPiServer" />
<add name="ClientToolsActivationKey" type="System.String" />
<add name="FrameworkName" type="System.String" />
</properties>
<providers>
<clear />
<add name="SqlProfile" type="System.Web.Profile.SqlProfileProvider, System.Web, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a" connectionStringName="EPiServerDB" applicationName="EPiServerSample" />
</providers>
</profile>
<!-- DYNAMIC DEBUG COMPILATION
Set compilation debug="true" to enable ASPX debugging. Otherwise, setting this value to
false will improve runtime performance of this application.
Set compilation debug="true" to insert debugging symbols (.pdb information)
into the compiled page. Because this creates a larger file that executes
more slowly, you should set this value to true only when debugging and to
false at all other times. For more information, refer to the documentation about
debugging ASP .NET files.
<compilation debug="true" defaultLanguage="c#" targetFramework="4.0" optimizeCompilations="true">
<assemblies>
<add assembly="System.Core, Version=4.0.0.0, Culture=neutral, PublicKeyToken=B77A5C561934E089" />
<add assembly="System.Web.Extensions, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31BF3856AD364E35" />
<add assembly="System.Web.Abstractions, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31BF3856AD364E35" />
<add assembly="System.Web.Routing, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31BF3856AD364E35" />
<add assembly="System.Web.Mvc, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31BF3856AD364E35" />
<add assembly="System.Data.DataSetExtensions, Version=4.0.0.0, Culture=neutral, PublicKeyToken=B77A5C561934E089" />
<add assembly="System.Xml.Linq, Version=4.0.0.0, Culture=neutral, PublicKeyToken=B77A5C561934E089" />
<add assembly="System.Data.Linq, Version=4.0.0.0, Culture=neutral, PublicKeyToken=B77A5C561934E089" />
<add assembly="System.Web.Helpers, Version=2.0.0.0, Culture=neutral, PublicKeyToken=31BF3856AD364E35" />
<add assembly="System.Web.WebPages, Version=2.0.0.0, Culture=neutral, PublicKeyToken=31BF3856AD364E35" />
</assemblies>
</compilation>
<!-- CUSTOM ERROR MESSAGES
Set customError mode values to control the display of user-friendly
error messages to users instead of error details (including a stack trace):
"On" Always display custom (friendly) messages
"Off" Always display detailed ASP.NET error information.
"RemoteOnly" Display custom (friendly) messages only to users not running
on the local Web server. This setting is recommended for security purposes, so
that you do not display application detail information to remote clients.
<customErrors mode="Off" />
<!-- AUTHENTICATION
!!!! IMPORTANT SECURITY NOTE !!!!!
If you enable forms authentication by uncommenting the Forms authentication information below AND
you are using Windows 2000 (any version) as web server, you must enable the "Act as part of the
operating system" user right for the ASPNET user account. If this is not done, you will not be able
to logon with windows accounts, only Extranet accounts. However this may be regarded as compromising
the security on your system since the ASPNET account should be a low-privilege account.
This section sets the authentication policies of the application. Possible modes are "Windows", "Forms",
"Passport" and "None". However only "Windows" and "Forms" are supported by EPiServer.
<!-- authentication mode="Windows" / -->
<authentication mode="Forms">
<forms name=".EPiServerLogin" loginUrl="logga-in" timeout="120" />
</authentication>
<!-- APPLICATION-LEVEL TRACE LOGGING
Application-level tracing enables trace log output for every page within an application.
Set trace enabled="true" to enable application trace logging. If pageOutput="true", the
trace information will be displayed at the bottom of each page. Otherwise, you can view the
application trace log by browsing the "trace.axd" page from your web application
root.
<trace enabled="false" requestLimit="10" pageOutput="false" traceMode="SortByTime" localOnly="true" />
<!-- SESSION STATE SETTINGS
By default ASP .NET uses cookies to identify which requests belong to a particular session.
If cookies are not available, a session can be tracked by adding a session identifier to the URL.
To disable cookies, set sessionState cookieless="true".
<sessionState mode="InProc" stateConnectionString="tcpip=127.0.0.1:42424" sqlConnectionString="data source=127.0.0.1;user id=sa;password=" cookieless="false" timeout="20" />
<!-- GLOBALIZATION
This section sets the globalization settings of the application.
<globalization culture="en-US" uiCulture="sv" requestEncoding="utf-8" responseEncoding="utf-8" resourceProviderFactoryType="EPiServer.Framework.Localization.LocalizationServiceResourceProviderFactory, EPiServer.Framework" />
<pages validateRequest="false" enableEventValidation="true" pageParserFilterType="System.Web.Mvc.ViewTypeParserFilter, System.Web.Mvc, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31BF3856AD364E35" controlRenderingCompatibilityVersion="3.5" clientIDMode="AutoID">
<controls>
<add tagPrefix="EPiServer" namespace="EPiServer.WebControls" assembly="EPiServer" />
<add tagPrefix="EPiServer" namespace="EPiServer.Web.WebControls" assembly="EPiServer" />
<add tagPrefix="EPiServer" namespace="EPiServer.Web.WebControls" assembly="EPiServer.Web.WebControls" />
<add tagPrefix="XForms" namespace="EPiServer.XForms.WebControls" assembly="EPiServer.XForms" />
<add tagPrefix="WebParts" namespace="EPiServer.WebParts.WebControls" assembly="EPiServer" />
<add tagPrefix="asp" namespace="System.Web.UI" assembly="System.Web.Extensions, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31BF3856AD364E35" />
<add tagPrefix="asp" namespace="System.Web.UI.WebControls" assembly="System.Web.Extensions, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31BF3856AD364E35" />
<add tagPrefix="SKTF" namespace="SKTF.Web.WebControls" assembly="SKTF.Web" />
<add tagPrefix="EPiServer" namespace="EPiServer.Framework.Web.WebControls" assembly="EPiServer.Framework" />
</controls>
<namespaces>
<add namespace="System.Web.Mvc" />
<add namespace="System.Web.Mvc.Ajax" />
<add namespace="System.Web.Mvc.Html" />
<add namespace="System.Web.Routing" />
<add namespace="System.Linq" />
<add namespace="System.Collections.Generic" />
<add namespace="EPiServer" />
<add namespace="EPiServer.Core" />
<add namespace="SKTF.Web.Util" />
<add namespace="SKTF.ContentEntities.Extensions" />
<add namespace="Avantime.CMS" />
<add namespace="EPiCode.Extensions" />
<add namespace="SKTF.Common.Extensions" />
<add namespace="System.Web.Helpers" />
<add namespace="System.Web.WebPages" />
<add namespace="EPiServer.Framework.Web.Mvc.Html" />
<add namespace="EPiServer.Shell.Web.Mvc.Html" />
</namespaces>
</pages>
<caching>
<outputCacheSettings>
<outputCacheProfiles>
<add name="ClientResourceCache" enabled="false" duration="0" varyByParam="*" varyByContentEncoding="gzip;deflate" />
</outputCacheProfiles>
</outputCacheSettings>
</caching>
<httpModules>
<add name="ErrorLog" type="Elmah.ErrorLogModule, Elmah" />
<add name="ErrorMail" type="Elmah.ErrorMailModule, Elmah" />
<add name="ErrorFilter" type="Elmah.ErrorFilterModule, Elmah" />
<!-- This is for IIS5, IIS6, and IIS7 Classic, and Cassini/VS Web Server-->
<add name="ImageResizingModule" type="ImageResizer.InterceptModule" />
<add name="RequestReduce" type="RequestReduce.Module.RequestReduceModule, RequestReduce" />
</httpModules>
<httpHandlers>
<add verb="POST,GET,HEAD" path="elmah.axd" type="Elmah.ErrorLogPageFactory, Elmah" />
<add path="*.less" verb="GET" type="dotless.Core.LessCssHttpHandler, dotless.Core" />
<remove path="*.less" verb="GET" />
</httpHandlers>
<httpRuntime requestValidationMode="2.0" />
</system.web>
<system.serviceModel>
<serviceHostingEnvironment aspNetCompatibilityEnabled="true" multipleSiteBindingsEnabled="true" />
<client>
<endpoint address="http://sktf.applicationservices.local/OccupationService.svc" binding="wsHttpBinding" bindingConfiguration="AppService" contract="SKTF.Data.IOccupationService" name="OccupationService" />
<endpoint address="http://sktf.applicationservices.local/FeedService.svc" binding="wsHttpBinding" bindingConfiguration="AppService" contract="SKTF.Data.IFeedService" name="FeedService" />
<endpoint address="http://sktf.applicationservices.local/OrganisationService.svc" binding="wsHttpBinding" bindingConfiguration="AppService" contract="SKTF.Data.IOrganisationService" name="OrganisationService" />
<endpoint address="http://sktf.applicationservices.local/MemberService.svc" binding="wsHttpBinding" bindingConfiguration="AppService" contract="SKTF.Data.IMemberService" name="PersonService" />
<endpoint address="http://sktf.applicationservices.local/StudentMemberService.svc" binding="wsHttpBinding" bindingConfiguration="AppService" contract="SKTF.Data.IStudentMemberService" name="StudentService" />
<endpoint address="http://sktf.applicationservices.local/CourseService.svc" binding="wsHttpBinding" bindingConfiguration="AppService" contract="SKTF.Data.ICourseService" name="CourseService" />
<endpoint address="http://avantime.messagehub:8090/MessageHubService" binding="basicHttpBinding" bindingConfiguration="BasicHttpBinding_IMessageHubWcfService" behaviorConfiguration="BasicHttpBinding_IMessageHubWcfService_Behavior" contract="MessageHubService.IMessageHubWcfService" name="BasicHttpBinding_IMessageHubWcfService" />
<!-- Uncomment this endpoint and the "RemoteEventServiceEndPoint" to enable remote events -->
<endpoint name="RemoteEventServiceClientEndPoint" address="soap.udp://239.255.255.19:5000/RemoteEventService" binding="customBinding" bindingConfiguration="RemoteEventsBinding" contract="EPiServer.Events.ServiceModel.IEventReplication" />
</client>
<bindings>
<customBinding>
<binding name="RemoteEventsBinding">
<binaryMessageEncoding />
<udpTransportCustom multicast="True" />
</binding>
</customBinding>
<wsHttpBinding>
<binding name="AppService" closeTimeout="00:03:00" openTimeout="00:03:00" receiveTimeout="00:30:00" sendTimeout="00:03:00" bypassProxyOnLocal="false" transactionFlow="false" hostNameComparisonMode="StrongWildcard" maxBufferPoolSize="4194304" maxReceivedMessageSize="4194304" messageEncoding="Text" textEncoding="utf-8" useDefaultWebProxy="true" allowCookies="false">
<readerQuotas maxDepth="32" maxStringContentLength="4194304" maxArrayLength="4194304" maxBytesPerRead="4194304" maxNameTableCharCount="4194304" />
<reliableSession ordered="true" inactivityTimeout="00:10:00" enabled="false" />
<security mode="None">
<transport clientCredentialType="Windows" proxyCredentialType="None" realm="" />
<message clientCredentialType="Windows" negotiateServiceCredential="true" />
</security>
</binding>
</wsHttpBinding>
<webHttpBinding>
<binding name="JobSearchWebBindingSecure" maxBufferPoolSize="2147483647" maxBufferSize="2147483647" maxReceivedMessageSize="2147483647" useDefaultWebProxy="true">
<security mode="Transport">
</security>
</binding>
<binding name="JobSearchWebBinding" maxBufferPoolSize="2147483647" maxBufferSize="2147483647" maxReceivedMessageSize="2147483647" useDefaultWebProxy="true">
</security>
</binding>
<binding name="MessageHubWebBindingSecure">
</security>
</binding>
<binding name="MessageHubWebBinding">
</security>
</binding>
<binding name="IndexingServiceCustomBinding" maxBufferPoolSize="1073741824" maxReceivedMessageSize="2147483647" maxBufferSize="2147483647">
<readerQuotas maxStringContentLength="10000000" />
</binding>
</webHttpBinding>
<basicHttpBinding>
<binding name="BasicHttpBinding_IMessageHubWcfService" maxReceivedMessageSize="9999999" />
</basicHttpBinding>
</bindings>
<extensions>
<bindingElementExtensions>
<add name="udpTransportCustom" type="Microsoft.ServiceModel.Samples.UdpTransportElement, EPiServer.Events" />
</bindingElementExtensions>
</extensions>
<services>
<!-- In order to get fault information from the server for debug purposes, add behaviorConfiguration="DebugServiceBehaviour" to the endpoint "RemoteEventServiceEndPoint" -->
<service name="EPiServer.Events.Remote.EventReplication">
<!-- Uncomment this endpoint and the "RemoteEventServiceClientEndPoint" to enable remote events
<endpoint name="RemoteEventServiceEndPoint"
address="soap.udp://239.255.255.19:5000/RemoteEventService"/>-->
</service>
<service name="SKTF.Services.JobSearchService">
<endpoint address="" binding="webHttpBinding" behaviorConfiguration="JobSearchRestServiceBehavior" bindingConfiguration="JobSearchWebBinding" contract="SKTF.Services.Contracts.IJobSearchService" />
<!--endpoint address=""
bindingConfiguration="JobSearchWebBindingSecure"
contract="SKTF.Services.Contracts.IJobSearchService" /-->
</service>
<service name="SKTF.Services.NetworkService">
<endpoint address="" binding="webHttpBinding" behaviorConfiguration="JobSearchRestServiceBehavior" bindingConfiguration="JobSearchWebBinding" contract="SKTF.Services.Contracts.INetworkService" />
contract="SKTF.Services.Contracts.INetworkService" /-->
</service>
<service name="Avantime.MessageHub.Services.WorkflowService">
<endpoint address="" binding="webHttpBinding" behaviorConfiguration="MessageHubRestServiceBehavior" bindingConfiguration="MessageHubWebBinding" contract="Avantime.MessageHub.Services.IWorkflowServiceContract" />
</service>
</services>
<behaviors>
<serviceBehaviors>
<behavior name="DebugServiceBehaviour">
<serviceDebug includeExceptionDetailInFaults="true" />
</behavior>
</serviceBehaviors>
<endpointBehaviors>
<behavior name="JobSearchRestServiceBehavior">
<webHttp />
</behavior>
<behavior name="MessageHubRestServiceBehavior">
<webHttp />
</behavior>
<behavior name="BasicHttpBinding_IMessageHubWcfService_Behavior">
<dataContractSerializer maxItemsInObjectGraph="10000000" />
</behavior>
</endpointBehaviors>
</behaviors>
</system.serviceModel>
<system.webServer>
<modules runAllManagedModulesForAllRequests="true">
<add name="InitializationModule" type="EPiServer.Framework.Initialization.InitializationModule, EPiServer.Framework" preCondition="managedHandler" />
<add name="FirstBeginRequestModule" type="EPiServer.Web.InitializationModule, EPiServer" preCondition="managedHandler" />
<add name="UrlRewriteModule" type="EPiServer.Web.RoutingUrlRewriteModule" preCondition="managedHandler" />
<add name="ShellRoutingModule" type="EPiServer.Shell.Web.Routing.ShellRoutingModule, EPiServer.Shell" />
<add name="HttpsRequiredModule" type="Avantime.CMS.Https.Core.HttpsRequiredModule, Avantime.CMS.Https, Version=1.0.0.0, Culture=neutral" preCondition="managedHandler" />
<add name="ErrorLog" type="Elmah.ErrorLogModule, Elmah" preCondition="managedHandler" />
<add name="ErrorMail" type="Elmah.ErrorMailModule, Elmah" preCondition="managedHandler" />
<add name="ErrorFilter" type="Elmah.ErrorFilterModule, Elmah" preCondition="managedHandler" />
<add name="NetworkRoutingModule" type="SKTF.Web.HttpModules.NetworkPathModule, SKTF.Web, Version=1.0.*, Culture=neutral" />
<!-- This is for IIS7+ Integrated mode -->
<remove name="WebDAVModule" />
</modules>
<handlers>
<add name="UrlRoutingHandler" preCondition="integratedMode" verb="*" path="UrlRouting.axd" type="System.Web.HttpForbiddenHandler, System.Web, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a" />
<add name="Elmah" path="elmah.axd" verb="POST,GET,HEAD" type="Elmah.ErrorLogPageFactory, Elmah" preCondition="integratedMode" />
<add name="SiteMap" verb="GET,HEAD" path="SiteMap.xml" type="Avantime.SEO.SiteMap.SiteMapHandler, Avantime.SEO.EPi7" />
<add name="Robots" verb="GET,HEAD" path="robots.txt" type=" Avantime.SEO.SiteMap.RobotsHandler, Avantime.SEO.EPi7" />
<add name="AspNetStaticFileHandler-CSS" path="*.css" verb="GET,HEAD" type="System.Web.StaticFileHandler" />
<add name="AspNetStaticFileHandler-JS" path="*.js" verb="GET,HEAD" type="System.Web.StaticFileHandler" />
<add name="AspNetStaticFileHandler-PNG" path="*.png" verb="GET,HEAD" type="System.Web.StaticFileHandler" />
<add name="AspNetStaticFileHandler-GIF" path="*.gif" verb="GET,HEAD" type="System.Web.StaticFileHandler" />
<add name="AspNetStaticFileHandler-JPG" path="*.jpg" verb="GET,HEAD" type="System.Web.StaticFileHandler" />
<add name="dotless" path="*.less" verb="GET" type="dotless.Core.LessCssHttpHandler,dotless.Core" resourceType="File" preCondition="" />
<remove name="dotless" />
</handlers>
<staticContent>
<clientCache cacheControlMode="UseMaxAge" cacheControlMaxAge="1.00:00:00" />
</staticContent>
<caching>
<profiles>
<add extension=".gif" policy="DontCache" kernelCachePolicy="CacheUntilChange" duration="0.00:01:00" location="Any" />
<add extension=".png" policy="DontCache" kernelCachePolicy="CacheUntilChange" duration="0.00:01:00" location="Any" />
<add extension=".js" policy="DontCache" kernelCachePolicy="CacheUntilChange" duration="0.00:01:00" location="Any" />
<add extension=".css" policy="DontCache" kernelCachePolicy="CacheUntilChange" duration="0.00:01:00" location="Any" />
<add extension=".jpg" policy="DontCache" kernelCachePolicy="CacheUntilChange" duration="0.00:01:00" location="Any" />
<add extension=".jpeg" policy="DontCache" kernelCachePolicy="CacheUntilChange" duration="0.00:01:00" location="Any" />
</profiles>
</caching>
<validation validateIntegratedModeConfiguration="false" />
<httpProtocol>
<customHeaders>
<add name="lb" value="01" />
</customHeaders>
</httpProtocol>
<httpErrors errorMode="Custom">
<remove statusCode="404" subStatusCode="-1" />
<error statusCode="404" path="/404/" responseMode="ExecuteURL" />
</httpErrors>
</system.webServer>
<system.codedom>
<compilers>
<compiler language="c#;cs;csharp" extension=".cs" type="Microsoft.CSharp.CSharpCodeProvider,System, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" warningLevel="4">
<providerOption name="CompilerVersion" value="v4.0" />
<providerOption name="WarnAsError" value="false" />
</compiler>
</compilers>
</system.codedom>
<microsoft.web.services3>
<messaging>
<transports>
<add scheme="soap.tcp">
<defaultPort value="8082" />
</add>
</transports>
</messaging>
</microsoft.web.services3>
<location path="elmah.axd">
<system.web>
<authorization>
<allow roles="WebAdmins, Administrators" />
<deny users="*" />
</authorization>
</system.web>
</location>
<location path="PageFiles">
<system.webServer>
<handlers>
<add name="webresources" path="WebResource.axd" verb="GET" type="System.Web.Handlers.AssemblyResourceLoader" />
<add name="wildcard" path="*" verb="*" type="EPiServer.Web.StaticFileHandler, EPiServer" />
</handlers>
</system.webServer>
<staticFile expirationTime="-1.0:0:0" />
</location>
<location path="Documents">
<system.webServer>
<handlers>
</handlers>
</system.webServer>
</location>
<location path="Global">
<system.webServer>
<handlers>
</handlers>
</system.webServer>
</location>
<location path="Contracts">
<system.webServer>
<handlers>
</handlers>
</system.webServer>
</location>
<location path="UploadDirectory">
<system.webServer>
<handlers>
</handlers>
</system.webServer>
</location>
<location path="BlogImages">
<system.webServer>
<handlers>
</handlers>
</system.webServer>
</location>
<location path="EPiServer">
<system.web>
<httpRuntime maxRequestLength="1000000" requestValidationMode="2.0" />
<pages enableEventValidation="true">
<controls>
<add tagPrefix="EPiServerUI" namespace="EPiServer.UI.WebControls" assembly="EPiServer.UI" />
<add tagPrefix="EPiServerScript" namespace="EPiServer.ClientScript.WebControls" assembly="EPiServer" />
<add tagPrefix="EPiServerScript" namespace="EPiServer.UI.ClientScript.WebControls" assembly="EPiServer.UI" />
</controls>
</pages>
<globalization requestEncoding="utf-8" responseEncoding="utf-8" />
<authorization>
<allow roles="WebEditors, WebAdmins, Administrators, FaIT_WebEditor, CMSEditors" />
<deny users="*" />
</authorization>
</system.web>
<system.webServer>
<handlers>
<clear />
<add name="svc-Integrated-4.0" path="*.svc" verb="*" type="System.ServiceModel.Activation.ServiceHttpHandlerFactory, System.ServiceModel.Activation, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35" preCondition="integratedMode,runtimeVersionv4.0" />
<add name="AssemblyResourceLoader-Integrated-4.0" path="WebResource.axd" verb="GET" type="System.Web.Handlers.AssemblyResourceLoader" preCondition="integratedMode,runtimeVersionv4.0" />
<add name="PageHandlerFactory-Integrated-4.0" path="*.aspx" verb="GET,HEAD,POST,DEBUG" type="System.Web.UI.PageHandlerFactory" modules="ManagedPipelineHandler" scriptProcessor="" resourceType="Unspecified" requireAccess="Script" allowPathInfo="false" preCondition="integratedMode,runtimeVersionv4.0" responseBufferLimit="4194304" />
<add name="SimpleHandlerFactory-Integrated-4.0" path="*.ashx" verb="GET,HEAD,POST,DEBUG" type="System.Web.UI.SimpleHandlerFactory" modules="ManagedPipelineHandler" scriptProcessor="" resourceType="Unspecified" requireAccess="Script" allowPathInfo="false" preCondition="integratedMode,runtimeVersionv4.0" responseBufferLimit="4194304" />
<add name="WebServiceHandlerFactory-Integrated-4.0" path="*.asmx" verb="GET,HEAD,POST,DEBUG" type="System.Web.Script.Services.ScriptHandlerFactory, System.Web.Extensions, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35" modules="ManagedPipelineHandler" scriptProcessor="" resourceType="Unspecified" requireAccess="Script" allowPathInfo="false" preCondition="integratedMode,runtimeVersionv4.0" responseBufferLimit="4194304" />
</handlers>
</system.webServer>
</location>
<location path="EPiServer/CMS/admin">
<system.web>
<authorization>
<deny users="*" />
</authorization>
</system.web>
</location>
<location path="EPiServer/Shell">
<system.web>
<authorization>
<allow roles="WebAdmins, WebEditors, Administrators, FaIT_WebEditor, MemberAdmins, CMSEditors" />
<deny users="*" />
</authorization>
</system.web>
</location>
<location path="Vision">
<system.web>
<authorization>
<allow roles="WebAdmins, Administrators, MemberAdmins" />
<deny users="*" />
</authorization>
</system.web>
</location>
<location path="Vision/Debug">
<system.web>
<authorization>
<deny users="*" />
</authorization>
</system.web>
</location>
Uncomment the following section replace UI in the path attribute with your customized UI path
to enable Office integration in the application.
<!--<location path="EPiServer/CMS/OfficeIntegration">
<system.web>
<authorization>
<allow users="*"/>
</authorization>
</system.web>
</location>-->
<location path="WebServices">
Configure the EPiServer.Security.BasicAuthentication module to send a basic authentication challenge
instead of a redirect to the forms login page. For this to take effect the EPiServer.Security.BasicAuthentication
module must be added to the list of http modules.
<episerver.basicAuthentication sendBasicChallenge="true" basicRealm="" />
<system.web>
<httpRuntime maxRequestLength="1000000" />
<authorization>
<allow roles="WebServices,Administrators" />
<deny users="*" />
</authorization>
</system.web>
<system.webServer>
<handlers>
<clear />
</handlers>
</system.webServer>
</location>
<location path="util">
<system.web>
<controls>
</controls>
</pages>
</system.web>
<system.webServer>
<handlers>
<clear />
</handlers>
</system.webServer>
</location>
<location path="App_Themes/Default">
<system.webServer>
<handlers>
<clear />
</handlers>
</system.webServer>
</location>
<episerver.framework configSource="EPiServerFramework.config" />
<episerver.shell>
<publicModules rootPath="~/modules/" autoDiscovery="Modules" />
<protectedModules rootPath="~/EPiServer/">
</protectedModules>
</episerver.shell>
<episerver.dataStore>
<dataStore defaultProvider="EPiServerSQLServerDataStoreProvider">
<providers>
<clear />
<add name="EPiServerSQLServerDataStoreProvider" description="SQL Server implementation of Data Store" type="EPiServer.Data.Dynamic.Providers.SqlServerDataStoreProvider, EPiServer.Data" />
</providers>
<cache defaultProvider="httpCacheProvider">
<providers>
<clear />
<add name="httpCacheProvider" description="Http Cache implementation for DataStore" type="EPiServer.Data.Cache.HttpRuntimeCacheProvider,EPiServer.Data.Cache" />
<add name="nullCacheProvider" description="Null Cache implementation for DataStore" type="EPiServer.Data.Cache.NullCacheProvider,EPiServer.Data" />
</providers>
</cache>
</dataStore>
</episerver.dataStore>
<episerver.search active="true">
<namedIndexingServices defaultService="serviceName">
<services>
<!--<add name="{serviceName}" baseUri="{indexingServiceBaseUri}" accessKey="{accessKey}"/>-->
<add name="serviceName" baseUri="http://sktf.web.local/IndexingService/IndexingService.svc" accessKey="local" />
</services>
</namedIndexingServices>
<searchResultFilter defaultInclude="true">
<providers />
</searchResultFilter>
</episerver.search>
<appSettings configSource="AppSettings.config" />
<elmah>
<errorLog type="Elmah.XmlFileErrorLog, Elmah" logPath="~/App_Data" />
<security allowRemoteAccess="1" />
</elmah>
<mailchimpSettings>
<features dynamicContentEnabled="true" modulePreviewTabEnabled="false" />
</mailchimpSettings>
<TradeDoublerConfig SecretCode="457254914" EventId="271153" OrganizationId="1782623" UtmSource="affiliates" UtmMedium="cpa" UtmCampaign="affiliatekampanj2013" />
<!--<pageTypeBuilder disablePageTypeUpdation="true" />-->
<RequestReduce cssProcesingDisabled="true" imageOptimizationDisabled="false" imageQuantizationDisabled="false" javascriptProcesingDisabled="true" imageSpritingDisabled="true" ignoreNearFutureJavascriptDisabled="true" authorizedUserList="epiadmin" contentStore="LocalDiskStore" storePollInterval="60000" connectionStringName="EPiServerDB" contentHost="" javascriptUrlsToIgnore="/util/,ajax.googleapis.com/ajax/libs/jquery/,ajax.aspnetcdn.com/ajax/jQuery/,www.googleadservices.com,googleads.g.doubleclick.net" />
<routeMappingSettings name="mappedUrls">
<urls>
<add url="Conversation" mappedUrl="/Network/Templates/ConversationPageTemplate.aspx" />
<add url="Profile" mappedUrl="/Network/Templates/ProfilePageTemplate.aspx" />
<add url="ProgramArrange" mappedUrl="/Network/Templates/Program/ProgramArrangePageTemplate.aspx" />
<add url="ProgramActive" mappedUrl="/Network/Templates/Program/ProgramActivePageTemplate.aspx" />
<add url="ProgramLast" mappedUrl="/Network/Templates/Program/ProgramPageTemplate.aspx" page="11655" />
<add url="ProgramCompleted" mappedUrl="/Network/Templates/Program/ProgramCompletedPageTemplate.aspx" page="11655" />
<add url="ProgramCancel" mappedUrl="/Network/Templates/Program/ProgramPageTemplate.aspx" page="11681" />
<add url="ProgramCanceled" mappedUrl="/Network/Templates/Program/ProgramPageTemplate.aspx" page="11658" />
</urls>
</routeMappingSettings>
<sktf.initialization>
<registries>
<add name="NetworkRepositories" type="SKTF.Network.Configuration.NetworkRegistryProvider, SKTF.Network" />
<add name="EPiNetworkRepositories" type="SKTF.Web.Network.Configuration.EPiNetworkRegistryProvider, SKTF.Web" topic-container="11668" messageSettingsPageId="11665" />
</registries>
</sktf.initialization>
<sktf.network settingsPageId="11661" rootUrlSegment="mentornatverket" inboxUrlSegment="inkorg" profileUrlSegment="profil" programUrlSegment="program" serviceUserRoles="NetworkAdmins" />
<avantime.messageHub>
<messageRepositories>
<add name="VisionEPiServerMessageRepository" type="SKTF.Apsis.Messages.VisionEPiServerMessageRepository, SKTF.Apsis" description="Email" pageLink="StartPage" pageTypeIds="41" />
</messageRepositories>
<senders>
<add name="ApsisSender" description="Email" type="SKTF.Apsis.Senders.ApsisSender, SKTF.Apsis" />
<add name="VisionSmsSender" description="Sms" type="SKTF.Apsis.Senders.VisionSmsSender, SKTF.Apsis" />
</senders>
<subscriberRepositories>
<add name="TestSubscriberRepository" type="Avantime.MessageHub.Tests.TestSubscriberRepository, Avantime.MessageHub.Tests" />
</subscriberRepositories>
</avantime.messageHub>
<messageHubMappings>
<PageMaps RenderPath="~/MessageHubResources/UI/" Routes="MH,MH/{Area}/,MH/{Area}/{WorkflowItemId}/">
<PageMap Name="Start" AvailableForGroups="*" Area="" RenderControl="Start.aspx" />
<PageMap Name="Create" AvailableForGroups="*" Area="Create" RenderControl="Create.aspx" />
<PageMap Name="Drafts" AvailableForGroups="*" Area="InProgress" RenderControl="InProgress.aspx" />
<PageMap Name="Status" AvailableForGroups="*" Area="Status" RenderControl="Status.aspx" />
<PageMap Name="History" AvailableForGroups="*" Area="History" RenderControl="History.aspx" />
<PageMap Name="Settings" AvailableForGroups="*" Area="Settings" RenderControl="Settings.aspx" />
<PageMap Name="Admin" AvailableForGroups="*" Area="Admin" RenderControl="Admin.aspx" />
<PageMap Name="Recipient" AvailableForGroups="*" Area="Recipient" RenderControl="RecipientSummary.aspx" />
<PageMap Name="Sending" AvailableForGroups="*" Area="Sending" RenderControl="SendingSummary.aspx" />
</PageMaps>
<StateMaps RenderPath="~/MessageHubResources/UI/Workflow/">
<StateMap State="DistributionSelect" RenderControl="DistributionSelect.ascx" AvailableForGroups="*" />
<StateMap State="WorkflowDetails" RenderControl="WorkflowDetails.ascx" SmsRenderControl="~/MessageHub/UI/WorkflowDetailsSms.ascx" AvailableForGroups="*" />
<StateMap State="ContentSelect" RenderControl="ContentSelect.ascx" SmsRenderControl="~/MessageHub/UI/SmsContentSelect.ascx" AvailableForGroups="*" />
<StateMap State="TestSend" RenderControl="TestSend.ascx" SmsRenderControl="~/MessageHub/UI/SmsTestSend.ascx" AvailableForGroups="*" />
<StateMap State="RecipientSelect" RenderControl="RecipientSelect.ascx" SmsRenderControl="~/MessageHub/UI/SmsRecipientSelect.ascx" AvailableForGroups="*" />
<StateMap State="ImportingRecipients" RenderControl="ImportingRecipients.ascx" SmsRenderControl="~/MessageHub/UI/ImportingRecipients.ascx" AvailableForGroups="*" />
<StateMap State="ImportRecipientsFailed" RenderControl="ImportRecipientsFailed.ascx" SmsRenderControl="~/MessageHub/UI/ImportRecipientsFailed.ascx" AvailableForGroups="*" />
<StateMap State="SendSelect" RenderControl="SendSelect.ascx" SmsRenderControl="~/MessageHub/UI/SmsSendSelect.ascx" AvailableForGroups="*" />
<StateMap State="ConfirmSending" RenderControl="ConfirmSending.ascx" AvailableForGroups="*" />
<StateMap State="InProgress" RenderControl="InProgress.ascx" AvailableForGroups="*" />
<StateMap State="Queued" RenderControl="Queued.ascx" AvailableForGroups="*" />
<StateMap State="Sent" RenderControl="Sent.ascx" AvailableForGroups="*" />
<StateMap State="Aborted" RenderControl="Aborted.ascx" AvailableForGroups="*" />
<StateMap State="Error" RenderControl="Error.ascx" AvailableForGroups="*" />
<StateMap State="Archived" RenderControl="Archived.ascx" AvailableForGroups="*" />
</StateMaps>
</messageHubMappings>
<CustomizableXhtmlPropertyConfiguration>
<Editors>
<Editor Name="DefaultEditor" Width="500" Height="300" ContentCss="">
<ToolbarRows>
<ToolbarRow>
<RowControls>
<RowControl ControlName="undo" />
<RowControl ControlName="redo" />
<RowControl ControlName="fullscreen" />
</RowControls>
</ToolbarRow>
<ToolbarRow>
<RowControls>
<RowControl ControlName="bullist" />
<RowControl ControlName="numlist" />
<RowControl ControlName="justifyleft" />
<RowControl ControlName="justifycenter" />
<RowControl ControlName="justifyright" />
<RowControl ControlName="bold" />
<RowControl ControlName="italic" />
<RowControl ControlName="underline" />
<RowControl ControlName="forecolor" />
<RowControl ControlName="removeformat" />
<RowControl ControlName="code" />
</RowControls>
</ToolbarRow>
<ToolbarRow>
<RowControls>
<RowControl ControlName="image" />
<RowControl ControlName="epiimageeditor" />
</RowControls>
</ToolbarRow>
<ToolbarRow>
<RowControls>
<RowControl ControlName="epidynamiccontent" />
<RowControl ControlName="separator" />
<RowControl ControlName="link" />
<RowControl ControlName="unlink" />
<RowControl ControlName="epilink" />
<RowControl ControlName="cut" />
<RowControl ControlName="paste" />
<RowControl ControlName="pastetext" />
</RowControls>
</ToolbarRow>
</ToolbarRows>
</Editor>
<Editor Name="MediumNews" Width="500" Height="300" ContentCss="">
<ToolbarRows>
<ToolbarRow>
<RowControls>
</RowControls>
</ToolbarRow>
<ToolbarRow>
<RowControls>
</RowControls>
</ToolbarRow>
<ToolbarRow>
<RowControls>
<RowControl ControlName="cleanup" />
</RowControls>
</ToolbarRow>
</ToolbarRows>
</Editor>
</Editors>
</CustomizableXhtmlPropertyConfiguration>
<ApsisConfig ApiKey="3d34ea5f-2a6d-4a0a-a12b-7e141e45fdd2" />
<resizer>
<!-- Unless you (a) use Integrated mode, or (b) map all reqeusts to ASP.NET,
you'll need to add .ashx to your image URLs: image.jpg.ashx?width=200&height=20 -->
<pipeline fakeExtensions=".ashx" />
<plugins>
<add name="MvcRoutingShim" />
<add name="DiskCache" />
</plugins>
</resizer>
<entityFramework>
<defaultConnectionFactory type="System.Data.Entity.Infrastructure.SqlConnectionFactory, EntityFramework" />
<contexts>
<context type="SKTF.Network.Data.NetworkContext, SKTF.Network">
</context>
<context type="Avantime.MessageHub.Data.DAL.MessageHubDbContext, Avantime.MessageHub.Data">
</context>
</contexts>
</entityFramework>
<dotless minifyCss="false" cache="true" web="false" />
<location path="Vision/Network">
<system.web>
<authorization>
<allow roles="WebAdmins, Administrators, MemberAdmins, NetworkAdmins" />
<deny users="*" />
</authorization>
</system.web>
</location>
<location path="modulesbin">
<system.web>
<authorization>
<deny users="*" />
</authorization>
</system.web>
</location>
<episerver.packaging protectedVirtualPath="~/EPiServer/" />
<episerver.search.indexingservice>
<clients>
<add name="local" description="local" allowLocal="true" readonly="false" />
</clients>
<namedIndexes defaultIndex="default">
<indexes>
<add name="default" directoryPath="D:\VPP\SKTF\Index" readonly="false" />
</indexes>
</namedIndexes>
</episerver.search.indexingservice>
<location path="IndexingService/IndexingService.svc">
<system.web>
<httpRuntime maxQueryStringLength="65536" />
</system.web>
<system.webServer>
<security>
<requestFiltering>
<requestLimits maxQueryString="65536" />
</requestFiltering>
</security>
</system.webServer>
</location>
</configuration>
#80106
Jan 15, 2014 8:58
I had the same problem with a site with SiteSeeker installed. If I remove those dll:s during the migration it works better.
#142135
Edited, Dec 01, 2015 18:48
