Get site hostname for each language?
Is it possible to get each hostname(s) for each language for a site in codebehind?
#79351
Dec 13, 2013 16:24
There is a class EPiServer.Globalization.HostLanguageResolver that might help you. There is a method GetHostForLanguage that you can use. The second parameter is the siteUrl for the site you want a host for, to use current site you can pass in EPiServer.Web.SiteDefinition.Current.SiteUrl.ToString()
#79356
Dec 13, 2013 18:08
Any example code you could provide?
#79384
Dec 16, 2013 11:35
Below is some code that iterates over all enabled languages and checks if they are mapped to a specific host (for current site). Note that the method returns null if the langauge is not mapped.
var languageHostResolver = ServiceLocator.Current.GetInstance<HostLanguageResolver>();
var currentSiteUrl = SiteDefinition.Current.SiteUrl.ToString();
foreach (var languageBranch in ServiceLocator.Current.GetInstance<ILanguageBranchRepository>().ListEnabled())
        var host = languageHostResolver.GetHostForLanguage(languageBranch.LanguageID, currentSiteUrl);
#79391
Dec 16, 2013 12:59
This dosen't work: var currentSiteUrl = SiteDefinition.Current.SiteUrl.ToString();
I get the error: 'EPiServer.Licensing.Services.SiteDefinition' does not contain a definition for 'Current'
What reference am i missing?
#79399
Dec 16, 2013 14:19
SiteDefinition resides in EPiServer.Web namespace (in EPiServer.dll)
#79400
Edited, Dec 16, 2013 14:20
Thanks, found it the second you reply. Now it works. :)
#79401
Dec 16, 2013 14:24
Thanks, Johan your solution helped me as well
#178988
May 29, 2017 12:02
