so it appears that my ~\EPiServer\CMS\7.5.394.2\Application is empty bar a few config files! Is it supposed to be this way?
so i have tried re-installing the core CMS, but none of the UI files are being installed! Can i copy across 7.0 to 7.5?
So i have upgraded all the way through from 6 R2, with coversion of Pagetype builder along the way!
The front end of the site is working now, but I am unable to acess the UI, it gives page cannot be found!
I've removed the sites node from episerver.config and have checked the the application settings node is in there.
In the framework config i have the virtual path providers in there as well:
What do i need to check to make sure all the ui stuff is pointing to the correct location.
Thanks!
Nick
