multiple files uppload problem
Can not uppload multiple files. The property "add multiple files" is anaktive.
#11367
Apr 04, 2007 11:00
You need to have the component for Advance File Upload installed and activated. This can be done under Root folder/Components.
#11739
Apr 04, 2007 15:56
how can I get this component
#11740
Apr 04, 2007 16:58
Look under Root folder/Components, the component should be visible there and available for installation (ActiveX component). Note though, the component will only work with Internet Explorer 7 if you have had the component installed and running with IE 6 before you upgrade to Internet Explorer 7.
#11741
Apr 05, 2007 10:55
#11742
Apr 10, 2007 9:10
#11743
Apr 10, 2007 9:22
To EPiServer: will there ever be an upgrade to make it possible to upload multiple files in episerver with explorer 7? Many customers is getting frustrated over this feature? /Wictor Stiebel
#11744
Jun 12, 2007 12:24
Hi. You need the IE7 compatibility fix for Client components. See the link below. http://www.episerver.com/en/EPiServer_Knowledge_Center/News--Information/News-Knowledge-Center/Changes-made-to-EPiServer-templates-for-IE7-compatibility/
#11745
Aug 10, 2007 13:36
I noticed someone else commented this, Look under Root folder/Components, the component should be visible there and available for installation (ActiveX component). Note though, the component will only work with Internet Explorer 7 if you have had the component installed and running with IE 6 before you upgrade to Internet Explorer 7. We have a client that cannot accept this. They will be running internet explorer 7 only. How can I resolve this issue? I have applied the 'IE7 compatibility fix for Client components', but this does not affect the activex component that the user downloads when they are on the 'components' tab in edit mode. Why does the activex component need to be applied to internet explorer 6 first? Is it the same activex component as ie7? Can we download an apply an activex component manually?
#11746
Aug 21, 2007 3:41
Any new status on this issue would be very much appreciated. We are facing the same problem, restricting installation of the EPiServer Client Components on IE 7. The “Install version 1.1” button is disabled under the Components tab. Regards, Leif
#11747
Dec 05, 2007 11:37
Are you using Windows Vista? Our project manager has the same problem, tho it only appears on Vista. Works perfectly on my XP installation.
#11748
Dec 06, 2007 12:00
Yes, I'm running Vista.
#11749
Dec 06, 2007 21:53
