Installation problem through web install
Hi, I have installed a new server with IIS, SQL 2005 Std and .NET 3.0. The installation went on fine and finished without any, or at least it said that. I start the page and everything seems to bee fine but when I try to login I get a page that say; Incorrect link The link you gave does not work, either because the page it points to has been deleted or moved. If you clicked on a link, please inform the site's webmaster that the link is faulty. Detailed error information (authorized by permissions to functions) Error occured 11/2/2007 4:27:21 PM User IP xxx.xxx.xxx.xxx User Agent Mozilla/4.0 (compatible; MSIE 6.0; Windows NT 5.2; SV1; .NET CLR 1.1.4322; .NET CLR 2.0.50727; .NET CLR 3.0.04506.30) Url http://localhost/admin/ Referer http://localhost/Util/login.aspx?ReturnUrl=/admin/ Exception details: HttpException: Not Found Http status: 404 NotFound Stack trace: [HttpException: Not Found] I have heard that it could have something to do with the templates you install but i can't remember what it was. If you have any ide what might have caused this I will be a happy listener. Regards Patrik
#11428
Nov 02, 2007 15:43
